[Mapserver-users] [gis newbie] Using my own data.
Nico Alberti
n8 at langhirano.it
Tue Apr 20 09:44:17 EDT 2004
Jan Hartmann disse:
> Hi Nico, could you please send your mapfile and the ogrinfo results to
> the list? It is probably a small matter, as you seem to have prepared
> everything OK.
Thanks Jan and Robert for trying to help me.
That is the ogrinfo output of my shp file:
C:\Documents and Settings\AlbertiNico\Documenti\Bonifica
PMS\Lavori\GIS\openev_fw\bin>ogrinfo -al
c:\Inetpub\wwwroot\tutorial\autbacpo\principali-parmigiana.shp
|more
INFO: Open of
`c:\Inetpub\wwwroot\tutorial\autbacpo\principali-parmigiana.shp'
using driver `ESRI Shapefile' successful.
Layer name: principali-parmigiana
Geometry: Line String
Feature Count: 29
Extent: (596060.125000, 894392.000000) - (658805.250000, 980522.500000)
Layer SRS WKT:
[...and so on...]
So, I stripped down the tutorial's example1-1.map this way:
MAP
IMAGETYPE PNG
EXTENT 596060.125000 894392.000000 658805.250000 980522.500000
#EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "autbacpo"
IMAGECOLOR 255 255 255
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME principali-parmigiana
DATA principali-parmigiana
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
# End of LAYER DEFINITIONS
END # end of map file/object
This way Mapserver refuses to build the image, while if I keep the old
EXTENT data from the original example, all I get is a blank image.
Moreover, if I run ogrinfo over the original "states_ugl" shape file of
example1-1.map, I get completely different values:
INFO: Open of `c:\Inetpub\wwwroot\tutorial\data\states_ugl.shp'
Layer name: states_ugl
Geometry: Polygon
Feature Count: 204
Extent: (-97.238976, 41.619778) - (-82.122902, 49.385620)
Now I am starting to think about a unit mismatch. May it be so? Again I am
very sorry to ask lame questions for a GIS professional, but until now I
never had to deal with these kind of problems.
Thanks again.
Ciao
Nico
