[Mapserver-users] pan/javascript
BONNER S KARGER
bskarger at students.wisc.edu
Tue Apr 20 09:53:49 EDT 2004
I had a similar problem, and Steve pointed me to look at the name of the main form that draws the map. In the example, it is called "mapserv" (hence the document.mapserv.zoom in the end of the script). If your form is not named "mapserv", it won't work.
something like this should work:
<form method="GET" name="mapserv" action="[program]">
Or if you don't want to change the form name to "mapserv", change the javascript to reflect the name of your form.
Good luck,
>>Bonner
----- Original Message -----
From: Kaps Stefan <0098kast at edu.fh-kaernten.ac.at>
Date: Monday, April 19, 2004 5:58 pm
Subject: [Mapserver-users] pan/javascript
> hello,
> i wanted to create a pan control as it is described in the
> tutorial. so i did the javascript part and the part with the arrows.
> <script language="javascript">
> var pansize = 0.80;
> function pan(direction) {
> var x, y;
> if(direction == 'n') {
> x = ([mapwidth]-1)/2.0;
> y = 0 - [mapheight]*pansize + [mapheight]/2.0;
> } else if(direction == 'nw') {
> x = 0 - [mapwidth]*pansize + [mapwidth]/2.0;
> } else if(direction == 'ne') {
> x = ([mapwidth]-1) + [mapwidth]*pansize - [mapwidth]/2.0;
> } else if(direction == 's') {
> y = ([mapheight]-1) + [mapheight]*pansize - [mapheight]/2.0;
> } else if(direction == 'sw') {
> } else if(direction == 'se') {
> } else if(direction == 'e') {
> y = ([mapheight]-1)/2.0;
> } else if(direction == 'w') {
> document.mapserv.zoom[0].selected = true;
> document.mapserv.imgxy.value = x + " " + y;
> document.mapserv.submit();
> </script>
> <td>align="right" bordercolor="#ECE9D8" bgcolor="#666666"><img
> src="/graphics/nw.gif" width="18" height="18" border="0" alt="pan
> northwest"></td>...
> thats all i did but it doesn't work... does anybody know what i've
> done wrong or what i have forgotten?!
> cheers,
> Stefan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
