[Mapserver-users] proj.4 stuff
Bob Basques
bob.basques at ci.stpaul.mn.us
Thu Apr 22 14:29:34 EDT 2004
Ok, I can't get it to work:
HELP!!
How do I translate this (From the MNDOT website)
PROJCS<br> <br> ["Ramsey - county coordinates - english",GEOGCS
["Ramsey - county coordinates - english",DATUM
["<custom>",SPHEROID
["<custom>",6378418.941,298.2572242549207]<br> ],PRIMEM
["Greenwich",0.0],UNIT
["Degree",0.0174532925199433]],PROJECTION
["Lambert_Conformal_Conic"],PARAMETER
["False_Easting",499999.999998],PARAMETER
["False_Northing",99999.9999996],PARAMETER
["Central_Meridian",-93.38333333333334],PARAMETER
["Standard_Parallel_1",44.88333333333333],PARAMETER
["Standard_Parallel_2",45.13333333333333],PARAMETER
["Latitude_Of_Origin",44.79111111111111],UNIT
["Foot_US",0.3048006096012192]
To an output projection in a MAP file.<br> <br> <br> Here is what
doesn't work ( i did get this to work once upon a time, but it was a
while ago.), also, once it works, can I add to the proj file with an
arbitrary number so I don't have to worry about it anymore, what numbers
are available for use?:
MAP
NAME 'test'
SIZE 800 650
STATUS ON
##IMAGECOLOR 254 254 254
EXTENT 332000 -18000 678000 328000
UNITS FEET
PROJECTION
"init=epsg:26915"
END
TRANSPARENT TRUE
##SYMBOL
##NAME 'circle'
##TYPE ELLIPSE
##POINTS 1 1 END
##FILLED TRUE
##END
LAYER
NAME 'tlg01'
DATA './data/tlg01/tlg_roads_l'
STATUS DEFAULT
TYPE LINE
##CLASS
##NAME 'TLG'
##SYMBOL 'circle'
##SIZE 5
##OUTLINECOLOR 0 0 0
##COLOR 255 101 101
##END
PROJECTION
##"init=epsg:26992"
"proj=utm"
"ellps=GRS80"
##"datum=nad83"
"zone=15"
"lat_0=44.88333333333333"
"lon_0=-93.38333333333334"
##"unit=foot_us"
END
END
END ## end Map
Thanks
bobb
