[Mapserver-users] proj.4 stuff
Frank Warmerdam
warmerdam at pobox.com
Thu Apr 22 16:28:48 EDT 2004
Bob Basques wrote:
> Ok, I can't get it to work:
> HELP!!
> How do I translate this (From the MNDOT website)
> PROJCS<br> <br> ["Ramsey - county coordinates - english",GEOGCS
> ["Ramsey - county coordinates - english",DATUM
> ["<custom>",SPHEROID
> ["<custom>",6378418.941,298.2572242549207]<br> ],PRIMEM
> ["Greenwich",0.0],UNIT
> ["Degree",0.0174532925199433]],PROJECTION
> ["Lambert_Conformal_Conic"],PARAMETER
> ["False_Easting",499999.999998],PARAMETER
> ["False_Northing",99999.9999996],PARAMETER
> ["Central_Meridian",-93.38333333333334],PARAMETER
> ["Standard_Parallel_1",44.88333333333333],PARAMETER
> ["Standard_Parallel_2",45.13333333333333],PARAMETER
> ["Latitude_Of_Origin",44.79111111111111],UNIT
> ["Foot_US",0.3048006096012192]
This corresponds to the PROJ.4 definition:
+proj=lcc +lat_1=44.88333333333333 +lat_2=45.13333333333333 +lat_0=44.79111111111111 +lon_0=-93.38333333333334
+x_0=152400.3048 +y_0=30480.06096 +a=6378418.941 +b=6357033.31 +to_meter=0.3048006096012192 +no_defs
I got this by putting your definition in a text file, trimming some of the
HTML junk out and then doing the following. The testepsg program in gdal/ogr
(needs to be forced to build ... not a default utility) converts between different
coordinate system formats. The ESRI:: prefix tells the program the. prj file has
ESRI WKT instead of OGR WKT.
warmerda at gdal2200[44]% testepsg ESRI::./wrk.prj
Which gave:
WKT[ESRI::./wrk.prj] =
PROJCS["Ramsey - county coordinates - english",
GEOGCS["Ramsey - county coordinates - english",
DATUM["<custom>",
SPHEROID["<custom>",6378418.941,298.2572242549207]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["False_Easting",499999.999998],
PARAMETER["False_Northing",99999.9999996],
PARAMETER["Central_Meridian",-93.38333333333334],
PARAMETER["Standard_Parallel_1",44.88333333333333],
PARAMETER["Standard_Parallel_2",45.13333333333333],
PARAMETER["Latitude_Of_Origin",44.79111111111111],
UNIT["Foot_US",0.3048006096012192]]
Simplified WKT[ESRI::./wrk.prj] =
DATUM["<custom>",
Old Style WKT[ESRI::./wrk.prj] = PROJCS["Ramsey - county coordinates - english",
GEOGCS["Ramsey - county coordinates - english",DATUM["<custom>",SPHEROID["
<custom>",6378418.941,298.2572242549207]],PRIMEM["Greenwich",0.0],UNIT["De
gree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["
False_Easting",499999.999998],PARAMETER["False_Northing",99999.9999996],PARAMETE
R["Central_Meridian",-93.38333333333334],PARAMETER["Standard_Parallel_1",44.8833
3333333333],PARAMETER["Standard_Parallel_2",45.13333333333333],PARAMETER["Latitu
de_Of_Origin",44.79111111111111],UNIT["Foot_US",0.3048006096012192]]
ESRI'ified WKT[ESRI::./wrk.prj] =
DATUM["D_<custom>",
SPHEROID["_lt_custom_gt",6378418.941,298.2572242549207]],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Lambert_Conformal_Conic"],
UNIT["Foot_US",0.30480060960121924]]
PROJ.4 rendering of [ESRI::./wrk.prj] = +proj=lcc +lat_1=44.88333333333333 +lat_
2=45.13333333333333 +lat_0=44.79111111111111 +lon_0=-93.38333333333334 +x_0=1524
92 +no_defs
and watch the world go round - Rush | Geospatial Programmer for Rent
