[Mapserver-users] mapObj clone() method problem
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 23 12:56:53 EDT 2004
Alexandros Chimarios wrote:
> Dear Frank,
> I have upgraded to Mapserver 4.2beta version and the clone method suceeded ...
> but only for the first time. When I try to clone a mapObj for second time I
> get a segmentation fault error.
I run your map through the map copy code, and sure enough there were lots of
problems. I have committed a bunch of patches to mapcopy.c in the development
trunk (not 4.2). While it was clean after that, I don't really trust the
map copying code. It is poorly tested, and likely buggy in other venues.
I am not sure if it is worth merging the mapcopy.c changes back into 4.2
before final release or not. I will leave that to Daniel.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
