[Mapserver-users] mapObj clone() method problem
Alexandros Chimarios
alhim at intracom.gr
Fri Apr 23 08:25:31 EDT 2004
Dear Frank,
I have upgraded to Mapserver 4.2beta version and the clone method suceeded ...
but only for the first time. When I try to clone a mapObj for second time I
get a segmentation fault error.
Initially I thought that it might be a memory problem but then I succesfully
tried the following code :
// FWG_Map inherits from mapObj.
mo = FWG_Map('/usr/local/apache2/cgi-bin/geodata/world.map')
mo1 = FWG_Map('/usr/local/apache2/cgi-bin/geodata/world.map')
mo2 = FWG_Map('/usr/local/apache2/cgi-bin/geodata/world.map')
mo3 = FWG_Map('/usr/local/apache2/cgi-bin/geodata/world.map')
mo4 = FWG_Map('/usr/local/apache2/cgi-bin/geodata/world.map')
This is my .map file :
SYMBOL
NAME "star"
TYPE TRUETYPE
FONT arial
CHARACTER "r"
END
# Start of map file
MAP
NAME Mediteranean
STATUS ON
SIZE 600 600
EXTENT 2.5256 21.5595 34.1734 53.2078
# EXTENT -180 -90 180 90
SHAPEPATH
"/root/downloads/Arc/Linux/ArcExplorerJava4.0.1/aej40exe/data/World"
IMAGECOLOR 60 175 220
IMAGETYPE JPEG
#SYMBOLSET '/root/projects/python/symbols.ini'
#TEMPLATE /usr/local/apache2/cgi-bin/index.html
# PROJECTION
# "init=epsg:2163"
#END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
#start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 4 4 END
FILLED TRUE
END
SYMBOL
NAME 'star'
TYPE VECTOR
FILLED TRUE
POINTS
0 .375
.35 .375
.5 0
.65 .375
1 .375
.75 .625
.875 1
.5 .75
.125 1
.25 .625
END
END
SYMBOL
NAME 'starc'
TYPE TRUETYPE
FILLED TRUE
FONT rwg
ANTIALIAS true
CHARACTER "*"
END
LAYER
NAME country
STATUS ON
DATA country
TYPE POLYGON
CLASS
STYLE
COLOR 150 120 80
OUTLINECOLOR 25 25 25
END
END
END
LAYER
NAME cities
STATUS ON
DATA cities
TYPE POINT
LABELITEM "NAME"
CLASS
STYLE
COLOR 255 255 0
#SYMBOL 'starc'
SYMBOL '/usr/local/apache2/cgi-bin/geodata/symbols/ctyhwy.png'
END
LABEL
COLOR 255 255 0
SIZE tiny
FONT arial
POSITION CL
PARTIALS TRUE
ANTIALIAS TRUE
MINDISTANCE 30
BUFFER 1
END
END
END
LAYER
CONNECTIONTYPE postgis
CONNECTION "user=alhim dbname=fremis_geo_db host=127.0.0.1"
DATA " geolocation from unit_tracks USING UNIQUE oid USING SRID =
-1 "
NAME "ships"
STATUS OFF
TYPE POINT
LABELITEM "unit_id"
CLASS
STYLE
COLOR 255 255 0
#SYMBOL 'starc'
END
LABEL
COLOR 255 255 0
SIZE tiny
FONT arial
POSITION CL
PARTIALS TRUE
ANTIALIAS TRUE
MINDISTANCE 30
BUFFER 1
END
END
END
END # end of map file definition
On Tuesday 20 April 2004 17:01, you wrote:
> Alexandros Chimarios wrote:
> > Hi all,
> > I have a problem using Python Mapscript. In particular when i invoke
> > mapObj.clone() method i got a segmentation fault. This is my source code
> > mo = mapObj('/usr/local/apache2/cgi-bin/geodata/world.map')
> > mo_clone = mo.clone()
> > However, when I created a subclass of mapObj, then the clone method run
> > normally. But i have noticed that the clone method runs ok for 2 times.
> > if I try to invoke it the 3rd time i get an segmenation fault again. For
> > example :
> Alexandros,
> I don't think you mentioned which version of MapServer/MapScript you were
> using. A bunch of fixes where implemented in the map cloning capability
> about six weeks ago by Sean and I. The 4.2 release should be in
> substantially better shape than older versions. If you still get the
> problem with 4.2 then please submit a bug report including your mapscript
> fragment, and the .map file you are working with. Generally it is easy to
> track down the problems given that and valgrind.
> Best regards,
