[Mapserver-users] SLD Problems for Win32
Rene Teniere
TENIERER at gov.ns.ca
Fri Apr 23 14:40:48 EDT 2004
Assefa,
I tested it and it works VIA WMS Server only. The client side does not
work. I guess that's more work for someone :(
Rene
>>> Yewondwossen Assefa <assefa at dmsolutions.ca> 2004-04-23 3:20:18 PM
Rene,
I was trying to reproduce your problem with my own data. Here is what
I have tested : sld containing 2 named layers and both named layers use
LineSymbolizers. I was able to render the map without problem.
I have setup a quick demo (using mapserver 4.2b1) so you can see the
slds.
http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline,WorldRoads&SLD=http://localhost/msapps/world_testdata/tests/sld_tests/sld_test_rene.xml&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927
http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline,WorldRoads&SLD=http://localhost/msapps/world_testdata/tests/sld_tests/sld_test_rene2.xml&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927
From what I gathered this is the type of sld's that you are having
problem with. Please have a look and let me know if that is the case.
(As you have seen I have not tested this using a wms client, but just a
http call to a wms server. I do not think that It matters though).
If you still have a problem, you might send me the wms server map
fileand releted sld with tests URL's so I can set it up here.
Best Regards,
Rene Teniere wrote:
> Hi All,
> Thought version 4.2b1 would have solved my problems, however, they
are
> still there. I can't seem to be able to add more than one NamedLayer
for
> each symbolizer type (ie: line, polygon, etc.). It works fine as long
as
> I don't have more than one layer per type. Example:
> This works:
> <StyledLayerDescriptor version="1.0.0">
> <NamedLayer>
> <Name>Shoreline</Name>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <LineSymbolizer>
> <Stroke>
> <CssParameter name="stroke">#000000</CssParameter>
> </Stroke>
> </LineSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> <NamedLayer>
> <Name>Lakes</Name>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#000000</CssParameter>
> </Fill>
> <Stroke>
> </Stroke>
> </PolygonSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> This doesn't:
> <NamedLayer>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <LineSymbolizer>
> <Stroke>
> </Stroke>
> </LineSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> <NamedLayer>
> <Name>Rivers</Name>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <LineSymbolizer>
> <Stroke>
> <CssParameter name="stroke">#0000ff</CssParameter>
> </Stroke>
> </LineSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> <NamedLayer>
> <Name>Lakes</Name>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Fill>
> </Fill>
> <Stroke>
> </Stroke>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> Server Mapfile:
> MAP
> NAME "Base Data WMS Map File"
> SHAPEPATH "d:/GIS_Data/"
> SYMBOLSET "c:/Inetpub/wwwroot/wms/etc/nsdnr_symbols.sym"
> FONTSET "c:/Inetpub/wwwroot/wms/etc/fonts.txt"
> STATUS ON
> WEB
> IMAGEPATH "c:/temp/tmp/"
> IMAGEURL "/temp/tmp/"
> METADATA
> "wms_title" "Nova Scotia NFIS Server"
> "wms_onlineresource"
"http://10.2.185.9/cgi-bin/mapserv41.exe?map=/inetpub/wwwroot/wms/basewms.map&"
> "wms_srs" "EPSG:2038"
> #Optional wms entries:
> "wms_contactperson" "Richard Morash"
> "wms_contactorganization" "Nova Scotia Department of
> Natural Resources, Forestry Division"
> "wms_contactposition" "GIS Project Manager"
> "wms_abstract" "Nova Scotia Department of
> Natural Resources Forestry Division. This is Nova Scotia's Base Data
> Open GIS Consortium Web Map Server for sustainable forest
management."
> "wms_keywordlist"
> "WAP,Forest,Information,System,gis,sustainable,management"
> "wms_addresstype" "Postal"
> "wms_address" "664 Prince Street PO BOX
68"
> "wms_city" "Truro"
> "wms_stateorprovince" "Nova Scotia"
> "wms_postcode" "B2N 5B8"
> "wms_country" "CANADA"
> "wms_contactvoicetelephone" "(902) 893-5657"
> "wms_contactfacsimiletelephone" "(902) 893-6102"
> "wms_contactelectronicmailaddress" "rmorash at gov.ns.ca"
> "wms_accessconstraints" "WMS image only"
> "wms_fees" "None"
> END
> END
> PROJECTION
> #UTM Zone 20 NAD83 for Nova Scotia
> "init=epsg:2038"
> END
> LAYER
> NAME "Shoreline"
> DATA "shoreutm/shoreutm"
> TYPE LINE
> GROUP "Base Data"
> METADATA
> "wms_title" "Shoreline"
> "wms_group_title" "Base Data"
> END
> CLASS
> STYLE
> SYMBOL 0
> COLOR 72 164 255
> SIZE 2
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> LAYER
> NAME "Lakes"
> #STATUS OFF
> DATA "nslake83/nslake83.shp"
> TYPE POLYGON
> GROUP "Base Data"
> METADATA
> "wms_title" "Lakes"
> END
> CLASS
> STYLE
> SYMBOL 0
> COLOR 132 193 255
> OUTLINECOLOR 0 0 230
> BACKGROUNDCOLOR 72 164 255
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> LAYER
> NAME "Rivers"
> STATUS OFF
> TYPE LINE
> TILEINDEX "coindex/coindex"
> TILEITEM "lorivers"
> GROUP "Base Data"
> CLASSITEM "rivers_id"
> METADATA
> "wms_title" "Rivers"
> END
> CLASS
> EXPRESSION /./
> STYLE
> SYMBOL 0
> COLOR 0 0 230
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> Client Mapfile:
> MAP
> NAME "Nova Scotia WAP Page"
> STATUS ON
> EXTENT 180504 4786079 806737 5255785
> SIZE 400 300
> IMAGETYPE PNG24
> IMAGECOLOR 255 255 255
> UNITS METERS
> RESOLUTION 90.714286
> WEB
> END
> QUERYMAP
> STATUS ON
> SIZE -1 -1
> COLOR 255 255 0
> STYLE HILITE
> END
> PROJECTION
> "init=epsg:2038"
> END
> SCALEBAR
> STATUS ON
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 0 0 0
> UNITS METERS
> INTERVALS 5
> SIZE 250 5
> STYLE 0
> POSITION LL
> LABEL
> TYPE BITMAP
> SIZE SMALL
> OFFSET 0 0
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 0 0 0
> PARTIALS TRUE
> FORCE FALSE
> END
> END
> OUTPUTFORMAT
> NAME "PNG24"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE RGB
> END
> REFERENCE
> IMAGE "d:/www/gmap/wap/images/keymap.png"
> SIZE 175 131
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> TEMPLATE "d:/www/gmap/wap/templates/legend_template_all.html"
> LABEL
> TYPE BITMAP
> SIZE SMALL
> COLOR 0 0 89
> END
> END
> LAYER
> NAME "Shoreline"
> GROUP "Base Data"
> STATUS ON
> TYPE LINE
> UNITS METERS
> SIZEUNITS PIXELS
> TOLERANCE 0
> TOLERANCEUNITS PIXELS
> CONNECTIONTYPE WMS
> CONNECTION
> METADATA
> "wms_name" "Shoreline"
> "wms_server_version" "1.1.1"
> "wms_formatlist"
> "image/png,image/gif,image/jpeg,image/wbmp"
> "wms_format" "image/png"
> "wms_connectiontimeout" "45"
> "wms_sld_url"
> "http://10.2.185.9/wms/sld/basewms_sld.xml"
> END
> END
> LAYER
> NAME "Lakes"
> GROUP "Base Data"
> STATUS ON
> TEMPLATE "d:/www/gmap/wap/templates/blank.html"
> TYPE POLYGON
> MAXSCALE 500000
> TOLERANCE 10
> CONNECTIONTYPE WMS
> CONNECTION
> METADATA
> "wms_name" "Lakes"
> "wms_formatlist"
> "wms_sld_url"
> END
> END
> LAYER
> NAME "Rivers"
> GROUP "Base Data"
> STATUS ON
> TYPE LINE
> MAXSCALE 500000
> TOLERANCE 10
> CONNECTIONTYPE WMS
> CONNECTION
> METADATA
> "wms_name" "Rivers"
> "wms_formatlist"
> "wms_sld_url"
> END
> END
> Thanks,
> Rene
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
