[Mapserver-users] MapFile Java parser
Jean-Henry Berevoescu
bjh at globexplorer.com
Sat Apr 24 15:42:12 EDT 2004
I'm need a MapFile Java parser and I'd like to know if there's any way I
can use the Yacc files from the MapServer's distribution in order to
generate the parser (with, say, JavaCC or Byacc/Java or any other similar
tool).
I can do an independent parser, but I think it will be the best to use
the same configuration as the one used by MapServer itself, in order
to achieve maximum compatibility.
Any help with this issue will be highly apreciated.
Thanks,
Jean
