[Mapserver-users] GPS data Projection
Changqing Zhou
czhou at cs.umn.edu
Sun Apr 25 21:19:31 PDT 2004
HI, I would greatly appreaciate your help on a projection question:
How do I display gps data in lat-long point format on top of the following
MNDOT base road shapefile? How to project the GPS data to the road map system?
(http://www.dot.state.mn.us/tda/basemap/metadata/Roads.htm)
Horizontal Coordinate Scheme UTM
Ellipsoid GRS80
Horizontal Datum NAD83
Horizontal Units Meters
Below is my simplified maplefile. Note I do not use any projections:
MAP
NAME Hennepin County
IMAGETYPE png
#EXTENT 201621.496941 -294488.285333 1425518.020722
498254.511514 # LAEA
EXTENT 439000 4960000 487000 5010000 #from arcview
#EXTENT -97.5 41.619778 -82.122902 49.38562 # Geographic
SIZE 800 600
SHAPEPATH "data"
SYMBOLSET "symbols/symbols35.sym"
FONTSET "fonts/fonts.list"
WEB
TEMPLATE 'hennepinRoads.html'
IMAGEPATH '/ApacheGroup/Apache2/htdocs/tmp/'
IMAGEURL '/tmp/'
END
PROJECTION
# This is Lambert Azimuthal Equal-Area projection for the
# Continental U.S.
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
# This is the EPSG code for
# Lambert Azimuthal Equal-Area projection for the U.S.
#"init=epsg:2163"
END
LAYER # Hennepin Road layer begins here
NAME hennepin_line
DATA hennepinm
STATUS DEFAULT
TYPE LINE
# PROJECTION
# "init=epsg:4326"
# END
CLASSITEM "Code"
CLASS
EXPRESSION '01'
COLOR 0 0 255
END
CLASS
EXPRESSION '02'
COLOR 0 0 255
END
CLASS
EXPRESSION '03'
COLOR 255 0 0
END
CLASS
EXPRESSION '04'
COLOR 0 255 255
END
END # Hennepin Roads layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file
Thanks,
Changqing
More information about the MapServer-users
