[Mapserver-users] Re: POSTGIS - subselect problem
Alexandros Chimarios
alhim at intracom.gr
Tue Apr 27 10:22:54 EDT 2004
Solved this problem on my own.
It is clearly mentioned in PostGIS manual that MapServer needs to have a
unique id in each row in a subselect. Therefore I created an index on unit_id
and I added the unit_id column in the query and worked.
DATA " geolocation from (SELECT geolocation, unit_id from unit_tracks) as foo
using unique unit_id using srid=-1 "
Regards
Alex
On Tuesday 27 April 2004 16:54, you wrote:
> Hello,
> I have a problem with POSTGIS and in particular with subselects. I have a
> POSTGIS layer and everything go well when i put :
> DATA " geolocation from unit_tracks USING UNIQUE unit_id USING SRID = -1
> ... but when i put the following data(which theoritically is the same data
> with the previous one) I get a segmentation fault :
> DATA " geolocation from (SELECT geolocation from unit_tracks) as foo using
> unique oid using srid=-1 "
> Could anyone explain me what's happening here since subselecting is very
> important thing.
> Thanx
> Alexandros.
