[Mapserver-users] Re: POSTGIS - subselect problem
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 27 10:56:24 EDT 2004
Good job! I think you should write a bug though because a segv is not a
very good error message and not helpful toward pointing you toward a
solution.
-Steve W.
Alexandros Chimarios wrote:
> Solved this problem on my own.
> It is clearly mentioned in PostGIS manual that MapServer needs to have a
> unique id in each row in a subselect. Therefore I created an index on unit_id
> and I added the unit_id column in the query and worked.
> DATA " geolocation from (SELECT geolocation, unit_id from unit_tracks) as foo
> using unique unit_id using srid=-1 "
> Regards
> Alex
> On Tuesday 27 April 2004 16:54, you wrote:
>>Hello,
>>I have a problem with POSTGIS and in particular with subselects. I have a
>>POSTGIS layer and everything go well when i put :
>>DATA " geolocation from unit_tracks USING UNIQUE unit_id USING SRID = -1
>>... but when i put the following data(which theoritically is the same data
>>with the previous one) I get a segmentation fault :
>>DATA " geolocation from (SELECT geolocation from unit_tracks) as foo using
>>unique oid using srid=-1 "
>>Could anyone explain me what's happening here since subselecting is very
>>important thing.
>>Thanx
>>Alexandros.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
