[Mapserver-users] phpMapScript unable to query PostGIS layer that has a Bit() column?
Perry Casson perry.casson at waypointinfo.com
Thu Apr 29 22:01:48 PDT 2004
I'm fairly new to all of this MapServer stuff but I appear to have ran
into a bug when trying to do a map query on a PostGIS layer that has a
column that is defined as bit(8).  Is this a known issue?  I'm running
version MapServer 4.0.2 (Linux)
Fatal error: [MapServer Error]: msPOSTGISLayerGetShape(): Error
executing POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor2 BINARY
CURSOR FOR SELECT
esn::text,gmuid::text,messageid::text,timestamp::text,recievedat::text,devicetype::text,identifier::text,isgps::text,longitude::text,latitude::text,gpsvalid::text,gpstime::text,v1::text,v2::text,v3::text,max1::text,max2::text,max3::text,actuator_previous::text,actuator_current::text,userdata::text,battery::text,asbinary(force_collection(force_2d(geo)),'NDR')
from wp_point WHERE OID = 27497 -ERROR: Cannot cast type bit to text
The table is defined like this:
CREATE TABLE wp_point(ESN varchar(12), gmUID varchar(40), messageID
varchar(40), TimeStamp timestamp, RecieveDat timestamp, DeviceType
varchar(32), Identifier varchar(32), IsGPS varchar(2), Longitude float8,
Latitude float8, GPSValid varchar(2), GPSTime timestamp, V1 int2, V2
int2, V3 int2, Max1 int2, Max2 int2, Max3 int2, Actuator_Previous bit(8)
, Actuator_Current bit(8) ,UserData varchar(64), Battery varchar(8));
Perry Casson
More information about the MapServer-users mailing list
