[Mapserver-users] Image handling error problem
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Fri Apr 30 03:39:26 EDT 2004
Roongrasamee Boondao schrieb:
> Dear Sirs,
> I have problem when try to access some layers on Internet. It shows the
> message
> as below. Would you be so kind to help me solve the problem? Thank you in
> advanced.
> msDrawMap(): Image handling error. Failed to draw layer named 'trans'.
> msSHPOpenFile(): Unable to access file.
> (/usr/local/apache2/htdocs/html/trans)
> (/usr/local/apache2/htdocs/html/data/MAP/trans)
> Best regards,
> _________________________________________________________________
> Protect your inbox from harmful viruses with new ninemsn Premium. Go
> to
> http://ninemsn.com.au/premium/landing.asp?banner=emailtag&referrer=hotmail
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Are you sure that the location of the data on the file system is the
same as described in the mapfile you are trying to use.
I tested it with one of my .map files that work and I only deleted the
last character of the data definition of the layer
to: DATA "ortslag"
and the result looks the same as your error.
Regards,
Norbert
