[Mapserver-users] Creating classes with data from a mysql database
Alexandros Chimarios
alhim at intracom.gr
Thu Apr 29 23:04:02 PDT 2004
First of all, you should select the columns you wish to appear in the
CLASSITEM and EXPRESSION in your data fiels like this :
DATA " geolocation from (SELECT unit_tracks.geolocation, unit_tracks.unit_id
,units.name , units.identification from unit_tracks LEFT JOIN units ON
unit_tracks.unit_id = units.unit_id) as foo using unique unit_id using
srid=-1 "
Then you set the EXPRESSION and CLASSITEM :
CLASSITEM "identification"
CLASS
EXPRESSION "UNKNOWN"
Hope this example helps. Please notice that no DB table expression are set in
CLASSITEM. If i put "CLASSITEM 'units.identification' " then I will get
an error. Once the data have been imported from the DB, MapServer treats them
as its own table.
Alexandros
On Friday 30 April 2004 05:26, Attri, Abhishek wrote:
> Hi All,
> I need to create classes on a map object based on data fetched from a
> MySQL database. The classes will be created and displayed based on the
> attributes in the MySQL table (These are not shapefiles). My confusion
> is what will go in the 'data' and 'classitem' fields of the layer
> object, and also how will I set an expression in the class based on
> MySQL table attributes.
> Any examples?
> With thanks in advance....
> Abhishek
More information about the MapServer-users
