[Mapserver-users] Creating classes with data from a mysql database
Attri, Abhishek
aattri at cba.ua.edu
Fri Apr 30 14:58:18 EDT 2004
Hi all,
I used the following syntax to query a mysql table and create a layer
and a class, and got the errors listed below.
$layer->set(data,"colname from (select table1.colname FROM table ,
table1 WHERE table.col1='xx' AND table.col2='xx2' AND
table.col3=table1.col3)");
$layer->set(classitem,"colname");
$class->setexpression('([colname]< 50000)');
line 75: $image=$map->draw();
line 77: $image_url=$image->saveWebImage();
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'county'. in /home/tech/abhi/public_html/mapExamples/Map2.php on line 75
Warning: [MapServer Error]: msSHPOpenFile():
(/home/tech/abhi/WWW/ms/map_files/) in
(/home/tech/abhi/WWW/ms/data/) in
Fatal error: Call to a member function on a non-object in
/home/tech/abhi/public_html/mapExamples/Map2.php on line 77
Also tha data with which i am trying to create a layer with, is not
related to the shapefiles at all. Its just a population variable, and i
want to color the map differently based on different
population values.
Please help me understand what the right method is to create a layer
dynamically from a mysql database, and then generate an image to be
displayed.
With thanks in advance..
Abhishek
-----Original Message-----
From: Alexandros Chimarios [mailto:alhim at intracom.gr]
Sent: Friday, April 30, 2004 1:04 AM
To: Attri, Abhishek; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Creating classes with data from a mysql
database
First of all, you should select the columns you wish to appear in the
CLASSITEM and EXPRESSION in your data fiels like this :
DATA " geolocation from (SELECT unit_tracks.geolocation,
unit_tracks.unit_id
,units.name , units.identification from unit_tracks LEFT JOIN units ON
unit_tracks.unit_id = units.unit_id) as foo using unique unit_id using
srid=-1 "
Then you set the EXPRESSION and CLASSITEM :
CLASSITEM "identification"
CLASS
EXPRESSION "UNKNOWN"
Hope this example helps. Please notice that no DB table expression are
set in
CLASSITEM. If i put "CLASSITEM 'units.identification' " then I will
get
an error. Once the data have been imported from the DB, MapServer treats
them
as its own table.
Alexandros
On Friday 30 April 2004 05:26, Attri, Abhishek wrote:
> Hi All,
> I need to create classes on a map object based on data fetched from a
> MySQL database. The classes will be created and displayed based on the
> attributes in the MySQL table (These are not shapefiles). My confusion
> is what will go in the 'data' and 'classitem' fields of the layer
> object, and also how will I set an expression in the class based on
> MySQL table attributes.
> Any examples?
> With thanks in advance....
> Abhishek
