[Mapserver-users] WMS test mapfile and Test server would be appreciated
Nicolas Boretos
nicolas at maich.gr
Fri Apr 30 05:35:19 EDT 2004
Arnulf Christl wrote:
> Hi,
> get the WMS GetCapabilities URL here:
> http://wms.ccgis.de/umn/bin/mapserv.exe?map=d:/umn/germany.map&request=capabilities&wmtver=1.0.0
Thank you Arnulf and Norbert,
With your help, I've managed to get somewhere...
Problems I noted were
1. I needed to set an environment variable PROJ_LIB since thet defaults
for windows e.g. C:\PROJ etc
did not work for me since msys paths are weird....This allowe my epsg
file to be found
2. I had to find another epsg file that contained your code..
3. As you suggested, I needed to set IMAGEPATH, URL to point to my machine??
I did not see the problem with the PNG lib, I used the PNG lib distro,
and I am using ms4.01 on WinXP...
Now to move on to WFS stuff
I,ve attached my mapfile incase it might help other...
thanx again, and regards,
nicolas boretos
MAP
NAME "test_cascading_WMS"
STATUS ON
EXTENT 4426500 5466000 4448000 5490200
PROJECTION
"init=epsg:31494"
END
SIZE 650 420
IMAGECOLOR 255 255 255
TRANSPARENT ON
UNITS meters #Units mapcoordinates; fu"r scale/scalebar Berechnungen
RESOLUTION 72 #Pixel/inch fu"r Output
(scalecomputation; def 72), vorher 300
INTERLACE OFF
IMAGETYPE PNG #output imagetype
WEB
FOOTER "cascade_wms.html"
HEADER "cascade_wms.html"
IMAGEURL "/cascade_wms/tmp/"
IMAGEPATH "c:/web/maich.gr/cascade_wms/tmp/"
TEMPLATE "cascade_wms.html"
MINSCALE 0
MAXSCALE 2000000
LOG "cascade_wms.log"
#IMAGEPATH "/data/umn/umn-www/sessions/"
#IMAGEURL "http://wms1.ccgis.de/umn/sessions/"
METADATA
"WMS_TITLE" "test_cascading_wms"
"WMS_ABSTRACT" "Test cascading WMS"
"WMS_ACCESSCONSTRAINTS" "none"
"WMS_SRS" "epsg:31494"
###THIS GETS WMS CAPABILITIES
###This gets my WMS Capabilities for this map
http://193.218.36.78/cgi-bin/ms401_static/mapserv.exe?map=c:/web/maich.gr/cascade_wms/cascade_wms.map&request=capabilities&wmtver=1.0.0
###"WMS_ONLINERESOURCE"
"http://192.168.2.71/cgi-bin/mapserv?map=/data/umn/test_cascading_wms.map"
"http://193.218.36.78/cgi-bin/ms401_static/mapserv?map=c:/web/maich.gr/cascade_wms/cascade_wms.map"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
END
END
LAYER
NAME "cascaded_WMS"
TYPE RASTER
STATUS ON
CONNECTION
"http://wms.ccgis.de/umn/bin/mapserv.exe?map=d:/umn/germany.map&wmtver=1.0.0"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "epsg:31494"
"wms_title" "cascaded WMS"
END
PROJECTION
"init=epsg:31494"
END
END
END
