[Mapserver-users] WMS test mapfile and Test server would be appreciated
Jeff McKenna
jmckenna at dmsolutions.ca
Fri Apr 30 10:12:37 EDT 2004
Nicolas,
You can now also use the "CONFIG" parameter in your mapfile to set the
location of your epsg files (see
http://mapserver.gis.umn.edu/doc/mapfile-reference.html#map). This was
recently added.
Jeff
> 1. I needed to set an environment variable PROJ_LIB since thet defaults
> for windows e.g. C:\PROJ etc
> did not work for me since msys paths are weird....This allowe my epsg
> file to be found
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
http://www.dmsolutions.ca
