Overlaying vectors on raster
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Aug 10 17:57:33 EDT 2004
It is easy to set the output projection to to that of you images and add
the same to all the image layers, then you can set the tiger layers to
have a different projection block. This will only cause the vector
layers to be reprojected.
I get pretty good registration between GPS tracks in the north-east and
tiger data without the need for any projection and the GPS is returning
data in WGS84 and the TIGER data is in NAD83 See here:
http://swoodbridge.com/moto/
Tiger data was collect in different ways in different areas. There are
some areas the that have poor registration and other with good. Check an
area in the north-east and see how it lines up. Tiger is going through a
modernization program and will be making a lot of updates over the next
few years so it will be ready for the 2010 census.
-Steve W
Randy Page wrote:
> Hi All,
> I’m working with Tiger data in the standard old geographic non-projection,
> and am attempting to overlay streets on top of aerials pulled in via WGS
> from USGS. The problem I am having is that the streets are WAY off in
> every location I try. I realize the Tiger data is not terribly accurate,
> but I have seen others do a much better job of overlaying the data. The
> aerials I am requesting are in EPSG 4326 (which is I believe WGS84
> geographic) while the Tiger data is in EPSG 4269 (which is I believe NAD83
> geographic.) I wouldn’t think the datum would make that much of a
> difference.
> The link below is to an example map that shows how far off the streets are:
> http://viewer.terraverge.net/viewer_mi/maps/sample.jpg
> Any ideas or suggestions?
> Thanks,
> Randy
