Error: legend template
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Tue Aug 24 22:53:02 EDT 2004
nhi791 at abdn.ac.uk wrote:
> Dear list:
> Does anyone know what is wrong? when I used Maplab MapBrowser and tried
> to open the tutorial map file: tutorial.map, the following message
> appeared in the Legend area and the legend did not appear:
> *Warning*: [MapServer Error]: generateLegendTemplate(): Error while
> opening template file. in
> *C:\msapps\maplab-2.2\htdocs\common\wrapper\map_session.php* on line *468
You would get this because the HMTL template filename specified in the
TEMPLATE parameter of the LEGEND object cannot be found. Make sure the
path and filename is valid.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
