Does MRSID SDK use Kakadu JPEG2000 ?
Richard E. Roger
richard.roger at AGRIC.NSW.GOV.AU
Wed Dec 8 21:03:41 EST 2004
Slightly off topic, I'm afraid...
I gather from Drew's message (below) that Geo_DSDK-4... is the MRSID SDK
which Lizardtech produce.
I note that the error message mentions "kdu_tile". This seems to be part
of the Kakadu Software JPEG2000 implementation (www.kakadusoftware.com).
Google "kdu_tile".
Does this mean that Lizardtech are licensing the Kakadu Software JPEG2000
SDK to provide their (Lizardtech's) JPEG2000 capabilities?
Anyone know, even if your response is of the "You may very well think that
but I couldn't possibly comment" variety?
Regards
Richard E. Roger
Dr. R. E. Roger NSW Department of
Primary Industries
Spatial Information Officer Systems 161 Kite St
Resource Information Unit Locked Bag 21
ORANGE NSW 2800
ph: (02) 6391 3697 fax: (02) 6391 3740
Date: Tue, 7 Dec 2004 08:39:44 -0600
Subject: Render Tiled JP2s with MRSID SDK enabled GDAL
I have an installation of MapServer 4.4.0 using GDAL 1.2.5 on Linux
2.4.20-28.8smp.
The GDAL is compiled with Geo_DSDK-4.0.9.713.
I have a tile index layer of jp2 files that am having trouble rendering at
certain scales.
At a small scale and large scale, the image renders ok, but in between I
get:
mapserv: ../compressed/codestream.cpp:3944: kdu_tile
kdu_codestream::open_tile(kdu_coords): Assertion `(tile_idx.x >= 0) &&
(tile_idx.x < state->num_tiles.x) && (tile_idx.y >= 0) && (tile_idx.y <
state->num_tiles.y)' failed.
I suspect an issue with the overviews in the jp2s:
Band 1 Block=6269x64 Type=Byte, ColorInterp=Red
Overviews: 3135x3508, 1567x1754, 784x877, 392x439, 196x219, 98x110,
49x55,
24x27, 12x14, 6x7, 3x3
Has anyone had a similar issue or have any suggestions?
Thanks for any help,
Drew.
This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient or
received it in error, please delete the message and notify sender. Views
expressed are those of the individual sender and are not necessarily the
views of their organisation.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041209/af6408ab/attachment.html
