How to render a layer with HTML/JS with MapServer 4.4.0
(configuration problem)
Ivano Picco
ivano.picco at AQUPI.TK
Mon Dec 13 08:06:30 EST 2004
Oh nooo!,
I think there's no way to get points from a layer without using a query
request, isn't it? But the wasted time waiting for a response it's long, as
you can read on my old post. I think the only affordable alternative way is
to use the GetMap with an easy modifiable output format like text/html.
However, thanks for your help,
Ivano Picco
On Mon, 13 Dec 2004 13:24:45 +0100, Bart van den Eijnden <bartvde at XS4ALL.NL>
wrote:
>Hi,
>I think that unfortunately you have run into something which is not
>possible with 4.4. AFAIK this will only be possible when the functionality
>to define your own outputformats has been realized, and the target for
>that one is FUTURE in bugzilla.
>"I will leave this open (and set it to FUTRUE) since we will need to
>instaure a user defined mecahnism to be able to advertize other formats."
>Best regards,
>Bart
