How to calculate LABELMINSCALE and LABELMAXSCALE
Holger Floerke
floerke at DOCTRONIC.DE
Mon Dec 13 09:39:32 EST 2004
Hi Steve,
I do not use the templates. I produce the map images with MapScript because
I have added some additional information like charts,... . Therefore I can't
use the [scale] variable in my template.
Any other idea? Or do I have to write a template just for this reason?
HolgeR
> The easiest way to know what scale you are at is to put [scale] in your
> template and it will display the current scale of the map on your HTML
> page. Then zoom in and out and see what scale you are at when you want
> to turn it on/off and round the values and put them in your mapfile.
> -Steve W.
> Holger Floerke wrote:
> > Hi there,
> > how can I calculate the LABELMINSCALE and LABELMAXSCALE parameters within my
> > mapfile? Is there a formula?
> > My shapefiles are coded with units dd and by "try and error" I guess some
> > *big* numbers for the scale. But I would like to calculate them.
> > TIA,
> > HolgeR
