Using Attributes
Cord Thomas
cord at LUPINEX.COM
Tue Dec 14 18:53:39 EST 2004
I believe the LAYER entry closest to what you want is STYLEITEM - but
reading docs, it appears to be experimental, and on how to use it is
unclear - i would guess the intention is that the attribute would point
to an indexed item in your STYLE collection. So, this would not be
appropriate for color.
Bob Basques wrote:
> All,
> I have a SHP file with a "COLOR" column in it with a RGB value (255 255
> 255).
> How do I use this in the MAPFILE as a COLOR value?
> I've been looking on and off all day in the Wiki, I've come to the
> conclusion that I'm not using the correct Search term. Does anyone have
> an example of how to use the column attribute value as the color value
> in the MAPFILE?
> LAYER
> NAME 'cities'
> DATA '<path to data>'
> STATUS DEFAULT
> CLASSITEM 'MUNI_NAME'
> CLASS
> OUTLINECOLOR 207 50 150
> COLOR '<value of muni_name column above>'
> SIZE 2
> SYMBOL 'circle'
> END
> END
> I think I'm having a brain freeze or something . . . . . mutter, mutter
> bobb
This email message is for the sole use of the intended recipient(s) and
may contain privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the intended
recipient, please contact the sender by reply email and destroy all copies
of the original message.
