Mapserver 4.4 timing out ( Windows Binaries )
Mike Davis
mike.and.kerry at GMAIL.COM
Wed Dec 15 15:34:48 EST 2004
I know the different binaries available are of different sizes
depending on how they were compiled. The Maptools binary seem to be
fairly large, but if you use the "kitchen sink" binary available is is
much smaller.
I have had similar problems when trying to replace our existing
maptools binaries with the "kitchen sink" builds from Iowa State
(http://hobu.stat.iastate.edu/mapserver/)
I think you need to double check all the dll's to make sure you have
the versions that came with the binary build you are using.
On Wed, 15 Dec 2004 15:24:35 -0500, Jeff McKenna
<jmckenna at dmsolutions.ca> wrote:
> Hi Jim,
> I believe the 4.4 mapserv.exe is around 3.7 MB. I would download it
> again: either by itself
> (http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html)
> or in the MS4W base package
> (http://www.maptools.org/ms4w/index.phtml?page=downloads.html).
> jeff
> Shanton, James A wrote:
> > When I try to zoom / Pan (jbox) with version 4.4 it works the first time
> > but then sits and times out the second time I try to do anything.
> > Is there something wrong with the windows binary (mapserv) ?
> > I'm using the mapserver 4.4 windows binaries, and I've noticed that the
> > mapserv.exe is only 36K. Is this correct ?
> > I was previously using Version 4.2.5 and its file size was about 2.5 MB. It
> > was working fine.
> > Is there something else I'm supposed to install with this version besides
> > the dlls that come with it ?
> > Thanks!
> > Jim Shanton
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
