[Mapserver-users] Too hard, too easy or too boring?
Pericles Nacionales
nacional at cbs.umn.edu
Tue Feb 3 19:07:01 EST 2004
I'm not a Solaris user but you might need additional FLAGS/LIBS to get
MapServer to work on that platform. Look at XTRALIBS in your Makefile and
make sure "-lm -lstdc++" are there. Perhaps it will work with other,
comparable libs.
Just guessing.
-Perry
On Tue, 3 Feb 2004, Keith Campbell wrote:
> OK, just trying to get your attention. I posted this yesterday under a
> different title and got no responses.
> Here's the problem. I'm trying to compila an install a WFS Server
> enabled Mapserver on a Solaris (this is proving to be a very frustrating
> experience, no doubt partly due to my lack of knowledge of UNIX). I
> think I've got all the libraries installed that I need, even though they
> are in non-standard locations (it's not my server). The configure script
> runs to completion and only seems to complain once:-
> checking for httpd... /export/home/local/apache2/bin/httpd
> awk: syntax error near line 1
> awk: bailing out near line 1
> /export/home/local/apache2/bin/httpd version is Apache/2.0.45 ().
> Not sure what this means or what the implications are.
> Anyway, this is what I fed into the configure:-
> bash$ ./configure --with-jpeg=/export/home/local/util/jpeg
> --with-freetype=/exp
> ort/home/local/util/freetype --with-zlib=/export/home/local/util/zlib
> --with-pn
> g=/export/home/local/util/libpng
> --with-libiconv=/export/home/local/util/libico
> nv --with-gd=/export/home/local/util/gd-2.0.15
> --with-proj=/export/home/local/u
> til/proj --with-ogr=/export/home/local/util/gdal/apps/gdal-config
> --with-gdal=
> /export/home/local/util/gdal/apps/gdal-config --with-wfs --with-postgis
> The make process ran for some time before spitting this out:-
> ld: fatal: relocation error: R_SPARC_32: file ./libmap.a(mapogr.o):
> symbol <unkn
> own>: offset 0xfd6609c9 is non-aligned
> symbol <unkn
> own>: offset 0xfd660a09 is non-aligned
> symbol <unkn
> own>: offset 0xfd660a69 is non-aligned
> symbol <unkn
> own>: offset 0xfd660c29 is non-aligned
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> I can't find anything in the archives that points to the cause of this.
> Can anybody help?
> Thanks,
> Keith
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
