[Mapserver-users] Segmentation fault - fedora
Shannon Scott
sscott at gwi.net
Wed Feb 4 13:22:38 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C3EB21.FA6DE4E0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Greetings.
We recently upgraded from RedHat 8.0 to the fedora OS.
Since then we have had trouble with one of our map files.
I searched for the error in the apache log "Premature end of script
headers: mapserv", but found no solution.
Then I tried the debugger.
I got this:
$ gdb mapserv
GNU gdb Red Hat Linux (5.3.90-0.20030710.41rh)
Copyright 2003 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "i386-redhat-linux-gnu"...(no debugging
symbols found)...Using host libthread_db library
"/lib/tls/libthread_db.so.1".
(gdb) run
"QUERY_STRING=map=/var/tomcat4/webapps/ROOT/static/mcht/mltn_query.map&m
ode=itemquery&qlayer=mltntrim&qitem=id&qstring=([id]=38)"
Starting program: /usr/local/mapserv_fedora/mapserver-4.0.1/mapserv
Program received signal SIGSEGV, Segmentation fault.
0x080566d9 in msReturnQuery ()
(gdb) backtrace
#0 0x080566d9 in msReturnQuery ()
#1 0x08051019 in msReturnTemplateQuery ()
#2 0x0804ec72 in main ()
(gdb)
Then I changed to itemnquery and got this:
$ gdb mapserv
are
conditions.
details.
(gdb) run
ode=itemnquery&qlayer=mltntrim&qitem=id&qstring=([id]=38)"
Content-type: text/html
<!-- MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF
INPUT=EPPL7 INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE -->
0x0031c153 in strlen () from /lib/tls/libc.so.6
(gdb) backtrace
#0 0x0031c153 in strlen () from /lib/tls/libc.so.6
#1 0x0035d23a in regexec () from /lib/tls/libc.so.6
#2 0x08055db4 in msReturnPage ()
#3 0x08056489 in msReturnQuery ()
#4 0x08051019 in msReturnTemplateQuery ()
#5 0x0804ec72 in main ()
(gdb)
How should I proceed?
Any help or advice is greatly appreciated.
Thank You.
Shannon
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3EB21.F57FAFE0">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><span class=3DGramE><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Greetings.</span></font></sp=
an><font
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span></font></p=
font-family:Arial'>We recently upgraded from <span =
class=3DSpellE>RedHat</span>
8.0 to the fedora OS.<o:p></o:p></span></font></p>
font-family:Arial'>Since then we have had trouble with one of our map =
files.<o:p></o:p></span></font></p>
font-family:Arial'>I searched for the error in the apache log =
“Premature
end of script headers: <span class=3DSpellE>mapserv</span>”, but =
found no solution.<o:p></o:p></span></font></p>
font-family:Arial'>Then I tried the =
debugger.<o:p></o:p></span></font></p>
font-family:Arial'>I got this:<o:p></o:p></span></font></p>
font-family:Arial'>$ <span class=3DSpellE><span =
class=3DGramE>gdb</span></span> <span
class=3DSpellE>mapserv</span><o:p></o:p></span></font></p>
font-family:Arial'>GNU <span class=3DSpellE>gdb</span> Red Hat Linux
(5.3.90-0.20030710.41rh)<o:p></o:p></span></font></p>
font-family:Arial'>Copyright 2003 Free Software Foundation, =
Inc.<o:p></o:p></span></font></p>
font-family:Arial'>GDB is free software, covered by the GNU General =
Public
License, and you are<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>welcome</span></font></span>=
<font
style=3D'font-size:10.0pt;font-family:Arial'> to change
it and/or distribute copies of it under certain =
conditions.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Type "show =
copying" to see
the conditions.</span></font></span><font size=3D2 face=3DArial><span
font-family:Arial'>There is absolutely no warranty for GDB.<span
style=3D'mso-spacerun:yes'> </span><span class=3DGramE>Type =
"show
warranty" for details.</span><o:p></o:p></span></font></p>
font-family:Arial'>This GDB was configured as =
"i386-redhat-linux-gnu"<span
class=3DGramE>...(</span>no debugging symbols found)...Using host <span
class=3DSpellE>libthread_db</span> library =
"/lib/tls/libthread_db.so.1".<o:p></o:p></span></font></p>
font-family:Arial'>(<span class=3DSpellE><span =
class=3DGramE>gdb</span></span>) run
"QUERY_STRING=3Dmap=3D/var/tomcat4/webapps/ROOT/static/mcht/mltn_que=
ry.map&mode=3Ditemquery&qlayer=3Dmltntrim&qitem=3Did&qstr=
ing=3D([id]=3D38)"<o:p></o:p></span></font></p>
font-family:Arial'>Starting program:
ing<span
class=3DGramE>=3D(</span>[id]=3D38)"<o:p></o:p></span></font></p>
font-family:Arial'>Program received signal SIGSEGV, Segmentation =
fault.<o:p></o:p></span></font></p>
font-family:Arial'>0x080566d9 in <span =
class=3DSpellE>msReturnQuery</span> ()<o:p></o:p></span></font></p>
class=3DGramE>gdb</span></span>) <span
class=3DSpellE>backtrace</span><o:p></o:p></span></font></p>
font-family:Arial'>#<span class=3DGramE>0<span =
</span>0x080566d9</span> in <span class=3DSpellE>msReturnQuery</span> =
font-family:Arial'>#<span class=3DGramE>1<span =
</span>0x08051019</span> in <span =
class=3DSpellE>msReturnTemplateQuery</span> =
font-family:Arial'>#<span class=3DGramE>2<span =
</span>0x0804ec72</span> in main ()<o:p></o:p></span></font></p>
class=3DGramE>gdb</span></span>)<o:p></o:p></span></font></p>
font-family:Arial'>Then I changed to <span =
class=3DSpellE>itemnquery</span> and got
Public
face=3DArial><span
<font
face=3DArial><span
copying" to see
"show
ry.map&mode=3Ditemnquery&qlayer=3Dmltntrim&qitem=3Did&qst=
ring=3D([id]=3D38)"<o:p></o:p></span></font></p>
font-family:Arial'>Starting program: =
ring<span
font-family:Arial'>Content-type: text/html<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><!--</span></font></span>=
<font
style=3D'font-size:10.0pt;font-family:Arial'> <span
class=3DSpellE>MapServer</span> version 4.0.1 OUTPUT=3DPNG OUTPUT=3DJPEG =
OUTPUT=3DWBMP
SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER INPUT=3DTIFF =
INPUT=3DEPPL7
INPUT=3DJPEG INPUT=3DGDAL INPUT=3DSHAPEFILE =
--><o:p></o:p></span></font></p>
font-family:Arial'>0x0031c153 in <span class=3DSpellE>strlen</span> () =
from
/lib/tls/libc.so.6<o:p></o:p></span></font></p>
</span>0x0031c153</span> in <span class=3DSpellE>strlen</span> () from
</span>0x0035d23a</span> in <span class=3DSpellE>regexec</span> () from
</span>0x08055db4</span> in <span class=3DSpellE>msReturnPage</span> =
font-family:Arial'>#<span class=3DGramE>3<span =
</span>0x08056489</span> in <span class=3DSpellE>msReturnQuery</span> =
font-family:Arial'>#<span class=3DGramE>4<span =
font-family:Arial'>#<span class=3DGramE>5<span =
font-family:Arial'>How should I proceed?<o:p></o:p></span></font></p>
font-family:Arial'>Any help or advice is greatly =
appreciated.<o:p></o:p></span></font></p>
font-family:Arial'>Thank You.<o:p></o:p></span></font></p>
<p class=3DMsoNormal><st1:place><font size=3D2 face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial'>Shannon</span></font></st1:place><font =
size=3D2
</div>
</body>
</html>
------=_NextPart_000_0001_01C3EB21.FA6DE4E0--
