[Mapserver-users] How to Install Mapserver on Debian woody?
woodbri at swoodbridge.com
Sun Feb 8 09:34:03 EST 2004
apt-get install mapserver
On 8 Feb 2004 at 14:55, Andreas Delleske wrote:
> Hello there,
> sorry, if it is a FAQ, but:
> How can I manage to compile mapserver 4.0.1 on a Debian 3.0 (woody)- system?
> Now, ./configure ends up with
> >zwei:~/mapserver-4.0.1# ./configure
> >loading cache ./config.cache
> >checking for gcc... gcc
> >checking whether the C compiler (gcc ) works... yes
> >checking whether the C compiler (gcc ) is a cross-compiler... no
> >checking whether we are using GNU C... yes
> >checking whether gcc accepts -g... yes
> >checking for c++... c++
> >checking whether the C++ compiler (c++ ) works... yes
> >checking whether the C++ compiler (c++ ) is a cross-compiler... no
> >checking whether we are using GNU C++... yes
> >checking whether c++ accepts -g... yes
> >checking for ranlib... ranlib
> >checking for flex... lex
> >checking for yywrap in -ll... no
> >checking for bison... no
> >checking for byacc... no
> >checking if compiler supports -R... no
> >checking if compiler supports -Wl,-rpath,... yes
> >checking for exp in -lm... yes
> >checking for __gxx_personality_v0 in -lstdc++... no
> >checking how to run the C preprocessor... gcc -E
> >checking for ANSI C header files... yes
> >checking for strcasecmp... yes
> >checking for strncasecmp... yes
> >checking for strdup... yes
> >checking whether we should include JPEG support...
> >checking for jpeg_read_header in -ljpeg... yes
> > using libjpeg from system libs.
> >checking where FreeType 2.x is installed...
> >checking for FT_Init_FreeType in -lfreetype... yes
> > using libfreetype -lfreetype from system libs.
> >checking where Zlib is installed...
> >checking for zlibVersion in -lz... yes
> > using libz from system libs.
> >checking where PNG is installed...
> >checking for png_init_io in -lpng... yes
> > using libpng from system libs.
> >checking where libXpm is installed...
> >checking for XpmFreeXpmImage in -lXpm... no
> > XPM (libXpm) library cannot be found, possibly needed for GD
> >checking where libiconv is installed...
> >checking for libiconv_open in -liconv... no
> > libiconv library cannot be found, possibly needed for GD
> >checking for GD 2.0.12 or higher...
> >checking for gdImageSetAntiAliased in -lgd... no
> >checking for gdImageSetAntiAliased in -lgd... (cached) no
> >configure: error: Could not find gd.h or libgd.a/libgd.so in
> >/usr/local. Make sure GD 2.0.12 or higher is compiled before calling
> >configure.
> All combinations I tried with
> ./configure -with-gd=/usr/local
> or something failed.
> maybe because gd.h is located /usr/include/gd.h
> and libgd.a an libgd.so are located in /usr/lib/libgd.so or /usr/lib/libgd.h
> GD 2.0 claims to be installed with the apt-get system
> Any ideas?
> Thanks in advance!
> Are there .deb packadges available? If yes, what do I have to do to
> install them as they do not seem to be part of the Debian-
> distribution?
> Gruss
> Andreas Delleske
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
