[Mapserver-users] How to Install Mapserver on Debian woody?
Bart van den Eijnden
bartvde at xs4all.nl
Sun Feb 8 09:20:16 EST 2004
with regard to the Debian packages, see:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00078.html
Best regards,
Bart
On Sun, 8 Feb 2004 14:55:59 +0100, Andreas Delleske <delleske at vauban.de>
wrote:
> Hello there,
> sorry, if it is a FAQ, but:
> How can I manage to compile mapserver 4.0.1 on a Debian 3.0 (woody)-
> system?
> Now, ./configure ends up with
>> zwei:~/mapserver-4.0.1# ./configure
>> loading cache ./config.cache
>> checking for gcc... gcc
>> checking whether the C compiler (gcc ) works... yes
>> checking whether the C compiler (gcc ) is a cross-compiler... no
>> checking whether we are using GNU C... yes
>> checking whether gcc accepts -g... yes
>> checking for c++... c++
>> checking whether the C++ compiler (c++ ) works... yes
>> checking whether the C++ compiler (c++ ) is a cross-compiler... no
>> checking whether we are using GNU C++... yes
>> checking whether c++ accepts -g... yes
>> checking for ranlib... ranlib
>> checking for flex... lex
>> checking for yywrap in -ll... no
>> checking for bison... no
>> checking for byacc... no
>> checking if compiler supports -R... no
>> checking if compiler supports -Wl,-rpath,... yes
>> checking for exp in -lm... yes
>> checking for __gxx_personality_v0 in -lstdc++... no
>> checking how to run the C preprocessor... gcc -E
>> checking for ANSI C header files... yes
>> checking for strcasecmp... yes
>> checking for strncasecmp... yes
>> checking for strdup... yes
>> checking whether we should include JPEG support...
>> checking for jpeg_read_header in -ljpeg... yes
>> using libjpeg from system libs.
>> checking where FreeType 2.x is installed...
>> checking for FT_Init_FreeType in -lfreetype... yes
>> using libfreetype -lfreetype from system libs.
>> checking where Zlib is installed...
>> checking for zlibVersion in -lz... yes
>> using libz from system libs.
>> checking where PNG is installed...
>> checking for png_init_io in -lpng... yes
>> using libpng from system libs.
>> checking where libXpm is installed...
>> checking for XpmFreeXpmImage in -lXpm... no
>> XPM (libXpm) library cannot be found, possibly needed for GD
>> checking where libiconv is installed...
>> checking for libiconv_open in -liconv... no
>> libiconv library cannot be found, possibly needed for GD
>> checking for GD 2.0.12 or higher...
>> checking for gdImageSetAntiAliased in -lgd... no
>> checking for gdImageSetAntiAliased in -lgd... (cached) no
>> configure: error: Could not find gd.h or libgd.a/libgd.so in
>> /usr/local. Make sure GD 2.0.12 or higher is compiled before calling
>> configure.
> All combinations I tried with
> ./configure -with-gd=/usr/local
> or something failed.
> maybe because gd.h is located /usr/include/gd.h
> and libgd.a an libgd.so are located in /usr/lib/libgd.so or
> /usr/lib/libgd.h
> GD 2.0 claims to be installed with the apt-get system
> Any ideas?
> Thanks in advance!
> Are there .deb packadges available? If yes, what do I have to do to
> install them as they do not seem to be part of the Debian- distribution?
