[Mapserver-users] WFS & OGR Virtual Datasource
Van Ulden, Joost
jvanulde at nrcan.gc.ca
Mon Feb 9 13:37:50 EST 2004
Ok, everything checks out with ogrinfo.
If I change the service to WMS everything works fine. The layers show up in
Capabilities and I can do a GetMap. Perfect. However, if I change the
service to WFS, none of my virtual datasources show up (but all my others
do) in Capabilites nor can I do a GetFeatureInfo... Thoughts?
Joost van Ulden
Programmer/Analyst
Natural Resources Canada / Ressources naturelles Canada
Geological Survey of Canada / Commission geologique du Canada
101 - 605 Robson Street / 101 - 605 rue Robson
Vancouver, B.C. / Vancouver (C.-B.)
V6B 5J3
Office/Bureau: 604.666.7525
fax/telecopieur: 604.666.1124
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Monday, February 09, 2004 9:57 AM
> To: Van Ulden, Joost
> Cc: Mapserver-Users at Lists. Gis. Umn. Edu
> (mapserver-users at lists.gis.umn.edu)
> Subject: Re: [Mapserver-users] WFS & OGR Virtual Datasource
> Van Ulden, Joost wrote:
> > Hi all,
> > I understand that an OGR virtual datasource can be exposed through
> > WMS, but what about WFS. So far I have had no luck doing
> this. Any
> > comments or suggestions would be helpful.
> Joost,
> This should work just fine. Does it work via WMS for you?
> The usual problem is that people have permissions issues with
> their ODBC data source or they get the naming conventions wrong.
> To debug I would encourage:
> o Verify your ODBC source is working with some external ODBC client.
> o Verify your ODBC source is working with OGR using the
> commandline utility
> ogrinfo.
> o Verify your virtual file definition is working with OGR
> using ogrinfo.
> Then try it with MapServer, keeping in mind these common issues:
> o If MapServer runs as a different user than you did all
> your previous testing,
> make sure that user has access to the ODBC data source
> (at the very least
> it needs to be a system DSN!)
> o Use a full path to the virtual file if you can't seem to
> get things working
> with a relative path.
> o Make sure the virtual file is readable by the user that
> mapserver runs as!
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
