[Mapserver-users] Mouse Over
Steve Lime
steve.lime at dnr.state.mn.us
Tue Feb 10 12:50:45 EST 2004
Hi all: The mapimage w/XML software was really more a proof-of-concept.
I never took it any further than that. The source is around if you're
interested. There are other possibilities as well. For example, in 4.0
there actually is a imagemap output object (see
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ImageMap) but I don't know
much about it. In 4.1 there is the [shpxy] tag and I've been planning to
add an attribute to allow you to output coordinates in IMAGE
coordinates. That way you could build an imagemap on the fly via the
CGI. It could also be used to populate DHTML popup objects (e.g.
http://www.bosrup.com/web/overlib/).
Would be happy to discuss further.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Bart van den Eijnden <bartvde at xs4all.nl> 2/7/2004 4:36:16 PM >>>
Hi Alex,
in Chameleon (www.maptools.org), which is based on PHP/Mapscript, there
is
functionality for this. It is called the "MapTips" widget. In this
widget
the approach you sketch is used (the image map approach). So if you
want
to know about performance etc, try it out with Chameleon. I don't know
about the Mapplet XML approach, maybe somebody else can comment on this
one.
Best regards,
Bart
On Sat, 07 Feb 2004 21:27:36 +0100, Alexander Pucher
<pucher at atlas.gis.univie.ac.at> wrote:
> Hi,
> this questions comes up every now and then...
> What is the current status, if I want to include mouse over events
with
> mapserver-php/mapscript. Suggestions of previous mails mentioned the
> "plain" image map solution, i.e. to generate an image map out of the
> geodata and overlay it over the rendered image.
> Are there some real-life examples for this?
> What might be the performance when using it with a ~3000 polygon
(~150
> points each) layer?
> What about the mapplet XML approach. Is there some documentation
> available for this?
> Regards,
> alex.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
