[Mapserver-users] new to mapserver - installation help
Michael Darweesh
mjd at mars.asu.edu
Tue Feb 10 16:42:53 EST 2004
Are the gdal and proj libraries in the library search path for the user
who runs httpd?
And, did you do a ldconfig (as root) on the machine running the httpd
after you installed the new libraries?
Based on that errorlog, I speculate that your mapserv isn't even
successfully executing when run as cgi.
Paste a copy of the ls -l of your mapserv's directory in your reply if
you could.
-Mike
arun at activeengineer.com wrote:
>Thank you Mike for your response. This is the error log:
>Premature end of script headers: /home/gishost/public_html/cgi-bin/mapserv
>As per your suggestion, I did check the permissions. mapserv is not owned by
>root.
>I am kind of puzzled since it works fine with same permissions if I compile
>mapserv without proj or gdal.
>Arun
>Quoting Michael Darweesh <mjd at mars.asu.edu>:
>>Double-check the permissions and file information on your mapserver
>>executable. the Redhat http doesn't like executing cgi where the
>>executable is owned by root. Though, I can't be sure that's your
>>installation's problem without more information. What does your
>>/var/www/http/error_log say when you try to run as cgi?
>>-Mike
>>>I am trying to install on Redhat. If I compile with GD and Freetype, it
>>tests
>>>fine from web browser. But thn if I add proj or gdal, it compiles fine and
>>>tests of from the command line but errors out ( Internal Server error 500 )
>>>from the web browser. File permissions are identical in both cases. CAn any
>>one
>>>throw some light please?
>>>Arun
>>>_______________________________________________
>>>Mapserver-users mailing list
>>>Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
