[Mapserver-users] new to mapserver - installation help
arun at activeengineer.com
Tue Feb 10 16:01:26 EST 2004
Thank you Mike for your response. This is the error log:
Premature end of script headers: /home/gishost/public_html/cgi-bin/mapserv
As per your suggestion, I did check the permissions. mapserv is not owned by
root.
I am kind of puzzled since it works fine with same permissions if I compile
mapserv without proj or gdal.
Arun
Quoting Michael Darweesh <mjd at mars.asu.edu>:
> Double-check the permissions and file information on your mapserver
> executable. the Redhat http doesn't like executing cgi where the
> executable is owned by root. Though, I can't be sure that's your
> installation's problem without more information. What does your
> /var/www/http/error_log say when you try to run as cgi?
> -Mike
> arun at activeengineer.com wrote:
> >I am trying to install on Redhat. If I compile with GD and Freetype, it
> tests
> >fine from web browser. But thn if I add proj or gdal, it compiles fine and
> >tests of from the command line but errors out ( Internal Server error 500 )
> >from the web browser. File permissions are identical in both cases. CAn any
> one
> >throw some light please?
> >Arun
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
