[Mapserver-users] Displaying x-y Datasets using PHP/Mapscript
Normand Savard
nsavard at dmsolutions.ca
Fri Feb 13 10:47:59 EST 2004
Hi Jan,
Frank sent a set debugging rules to follow on this mailing list
already. Maybe you could have a look to the following:
http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0402/msg00253.html
Also to verify if your current gdal/ogr installing support ODBC, you
could do "ogrinfo --formats".
Norm
Jan Vietmeier wrote:
>Hi,
>Thanks a lot for the Help. In the meantime I am able to dynamically add
>points to a layer using PHP/Mapscript, but the method suggested by Zak seems
>to be the best solution for my purpose.
>Now I am wading through the manual
>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData and
>everythink is working fine including the step "Testing" ... the virtual data
>file ... "using ogrinfo". The implementation into Mapserver fails with the
>error Message "... [MapServer Error]: msOGRFileOpen(): Open failed for OGR
>connection `D:\www\data\shapes\punktquelle.ovf'. File not found or
>unsupported format ...".
>In my opinion, this can have two reasons:
>1. My version of ogrinfo is from the openev_fw-Program downloaded at
>http://www.remotesensing.org and my mapserver-version is the binary-version
>from DM Solutions (mapserver-4.0-win32-php4.3.2.zip from 26-Aug-2003). Maybe
>my mapserver-version don't supports virtual layer.
>How can I find out if my gdal11.dll supports the ogr-vrt format (does
>gdalxx.dll contains ogr?)
>2. There is someting wrong with my mapfile or punktquelle.ovf-file. Here
>some code-snipps:
>The virtual layer file:
><OGRVRTDataSource>
> <OGRVRTLayer name="tbl_einsatz">
> <SrcDataSource>ODBC:@myeinsatz</SrcDataSource>
> <SrcTable>tbl_einsatz</SrcTable>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>The Mapfile:
> LAYER
> NAME "MyVirtualLayer"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "D:\www\polizei\data\shapes\punktquelle.ovf" # the name and
>path to the virtual.ovf file, relative to shapepath may work?
> DATA "tbl_einsatz" # the name of the OGRVrtLayer
> STATUS ON
> LABELITEM "Einsatz" #may need to use table.name or just name depending
>on your OVF file.
> PROJECTION
> "init=epsg:31468"
> END
> CLASS
> SYMBOL 1
> SIZE 6
> COLOR 255 0 0
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> COLOR 0 0 0
> END
> END
> END
>Does anyone have an idea?
>Tanks,
>Jan
>Jan Vietmeier, Diplom-Geograph
>Im Fichtenhain 18
>51069 Köln
>Tel. +49 (0)221 9468252
>Mobil +49 (0)178 3744854
>Fax. +49 (0)221 9468251
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
