AW: [Mapserver-users] Displaying x-y Datasets using PHP/Mapscript
Normand Savard
nsavard at dmsolutions.ca
Fri Feb 13 13:11:28 EST 2004
Jan,
There is a software to verify the library dependancy of an executable on
Windows. It is called "dependency-walker". (see
http://www.mozilla.org/quality/help/dependency-walker.html).
Norm
Jan Vietmeier wrote:
>Hi Morm,
>my ogrinfo.exe is from remotesensing.org and my gdal11.dll (which - I
>suppose - is used by the Mapserver and PHP/Mapscript) is from DM Solutions.
>My "virtual layer file" works fine with the command
>$ ogrinfo virtual.ovf mylayer
>but I am sure that Mapserver does NOT use the ogrinfo.exe for the virtual
>layer processing. I am not sure if my Mapserver supports odbc, because I
>don't know what *.exe or *.dll Mapserver needs for ogr-processing.
>I suppose ogr support is included in the gdal.dll is that right? In any
>case, the phpinfo() command tells following:
>MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS
>INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>regards,
>Jan
>Jan Vietmeier, Diplom-Geograph
>Im Fichtenhain 18
>51069 Köln
>Tel. +49 (0)221 9468252
>Mobil +49 (0)178 3744854
>Fax. +49 (0)221 9468251
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
