[Mapserver-users] Mapserver - Oracle through OGR
Vladimir Guzmán
bigfoot at main-task.com
Mon Feb 16 18:21:07 EST 2004
I have the same problem.
So I tried with the mapserver's built-in oracle spatial support, but I
have the following error:
[MapServer Error]: msOCIConnect() in msOracleSpatialLayerOpen():
ORA-07217: sltln: environment variable cannot be evaluated.
It is an Oracle error, which seems to be related with the environment
variable ORACLE_SID.
But it seems to be ok, because the ogrinfo works ok.
Any help will be greatly appreciated.
Thanks a lot,
Vladimir Guzmán
bartvde at xs4all.nl wrote:
>Hi list,
>I am trying to connect Mapserver to Oracle through OGR but I am running
>into a problem. Error message, output from ogrinfo and excerpt from MAP
>file at the bottom of this e-mail. We can connect through the native
>Oracle Spatial interface of Mapserver on the same machine.
>Anybody have an idea what could be the problem?
>Thanks in advance,
>Bart
>msDrawMap(): Image handling error. Failed to draw layer named 'straten'.
>msOGRFileOpen(): OGR error. Open failed for OGR connection
>`OCI:laura/laura at laura'. File not found or unsupported format.
>When I connect through ogrinfo there are no problems, this is part of the
>output generated by ogrinfo:
>INFO: Open of `OCI:laura/laura at laura'
>using driver `OCI' successful.
>Layer name: SELECT * from straten where name='Kerkstraat'
>Geometry: Unknown (any)
>Feature Count: 809
>Extent: (19361.400000, 309014.500000) - (276658.600000, 603186.200000)
>Layer SRS WKT:
>(unknown)
>FRC: Integer (9.0)
>NAMELC: String (3.0)
>ROUTENUM: String (50.0)
>MI_SYMBOLOGY: String (254.0)
>MI_PRINX: Integer (11.0)
>OGRFeature(SELECT * from straten where name='Kerkstraat'):0
> ID (Integer) = 2079166603
> FRC (Integer) = 7
> NAME (String) = Kerkstraat
> NAMELC (String) = DUT
> ROUTENUM (String) = (null)
> MI_SYMBOLOGY (String) = (null)
> MI_PRINX (Integer) = 312
> LINESTRING (268161.900 566095.100,268074.900 566072.700)
>This is the relevant part of my MAP file:
>NAME "STRATEN"
>CONNECTIONTYPE OGR
>CONNECTION "OCI:laura/laura at laura"
>DATA "SELECT * FROM STRATEN where name='Kerkstraat'"
>TYPE LINE
>No errors in the Apache error log.
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
