[Mapserver-users] Empty image with Oracle Spatial (polygons and lines)
arie van Halem
arie at vanhalem.net
Wed Feb 18 03:29:06 EST 2004
Hi List,
I've installed mapserver version 4.0.1 with Oracle input
(ms401_png_oracle.zip) on a windows2000 machine with apache 2. As I try to
get a map based on an oracle table I get an empty image.
The map definition I use is:
MAP
IMAGETYPE PNG
EXTENT -14000 294000 283750 641250
UNITS METERS
SIZE 600 400
IMAGECOLOR 255 255 0
SHAPEPATH "data"
DEBUG ON
WEB
LOG "\mslog.txt"
END
LAYER
DEBUG ON
NAME regio
CONNECTIONTYPE oraclespatial
CONNECTION "usr/pwd at orcl"
DATA "geom FROM regio USING SRID 90112"
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 128 128 128 # gray-filled
OUTLINECOLOR 0 0 0 # black contour
END
END
END
The request I use:
http://localhost/cgi-bin/mapserv.exe?map=/mapdata/test.map&mode=map
The logfile (\mslog.txt) shows:
Wed Feb 18 08:59:16 2004,2532,127.0.0.1,MS,3,-125988.125000 294000.000000
395738.125000 641250.000000,-1.000000 -1.000000,,normal execution
The apache error file shows:
[Wed Feb 18 08:59:16 2004] [error] [client 127.0.0.1] Wed Feb 18 08:59:16
2004 - msBuildPath: Unable to access file.
The query in oracle that mapsserver is running returns 25 rows (with
polygons), I tested that.
When I try to show point data based on an oracle table, mapserver does draw
it correctly. Polygon and line data is not drawn.
When I try to show the same data from a shape-file, mapserver does draw the
polygons correctly.
Can someone help me out?
Arie van Halem
- sorry for poor enlish -
