[Mapserver-users] WMS Not returning Image, but no errors
Swaminathan, Gayathri
gayathri at ou.edu
Wed Feb 18 12:03:48 EST 2004
You are correct. It could be that, your EPSG is wrong..
It could be that your BBOX request for your EPSG is not correct.
May be check that , and then alter WMS query accordingly....
You can start with a state/country level extent, to see if your
projection is appropriate and then zoom-in using BBOX.
HTH
Gayathri
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Mark Rodrigo
> Sent: Tuesday, February 17, 2004 10:05 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] WMS Not returning Image, but no errors
> Hi:
> Thanks for the responses. I have actually read the WMS 4.x
> doc in the Wiki, and it was there that it mentioned you
> should be able to get a basic map by submitting
(http://localhost/cgi-bin/mapserv.exe?map=gtest.map&VERSION=1.1.0&REQUES
T=Ge
tMap)
It draws nothing.
But, I have also tried statements like
(http://localhost/cgi-bin/mapserv.exe?map=gtest.map&VERSION=1.1.0&format
=ima
ge/gif&layers=road&bbox=-122.653,38.15,-122.08,38.85&SRS=EPSG:4269&width
=200
&height=200&request=getmap)
This draws nothing also. So, I am at a loss. I figure I have the wrong
EPSG, am missing some required parameter or for some reason my proj.dll
is not being read properly?
Thanks
Mark
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
