[Mapserver-users] Oracle Spatial extents
Vladimir Guzmán
bigfoot at main-task.com
Wed Feb 18 12:50:22 EST 2004
I have the same problem that using SDO_GEOM.SDO_MBR:
ORA-13374: SDO_MBR not supported for geodetic data
Do you know why my data is geodetic and yours not?
Did I create the table in the wrong way?
Thanks a lot.
Vladimir Ilich Guzmán R.
http://www.maintask.com
Fernando S. wrote:
> Vladimir,
> Hi, concerning this function, I don't know if this is the correct
> way to do it. Anyway I use this query to get the extent:
> SELECT max(X2), max(Y2), min(X1), min(Y1) FROM (
> SELECT SDO_GEOM.SDO_MAX_MBR_ORDINATE(h.coordenada,
> m.diminfo, 1) AS X2
> , SDO_GEOM.SDO_MAX_MBR_ORDINATE(h.coordenada,
> m.diminfo, 2) AS Y2
> , SDO_GEOM.SDO_MIN_MBR_ORDINATE(h.coordenada,
> m.diminfo, 1) AS X1
> m.diminfo, 2) as Y1
> , h.codigo_ott
> , h.codigo_dna
> FROM hidrografia_sc h, user_sdo_geom_metadata m
> WHERE m.table_name ='HIDROGRAFIA_SC'
> AND m.column_name = 'COORDENADA'
> AND h.codigo_ott = $CODE)
> In this query HIDROGRAFIA_SC is the table that contains the
> geometry column (COORDENADA). The $CODE is the unique identyfier of
> table.
> This query report:
> MAX(X2) MAX(Y2) MIN(X1) MIN(Y1)
> -48.64248 -26.83385 -49.69149 -27.24407
> I don't know if I help you. Sorry my poor english.
> Fernando Simon - simon at cttmar.univali.br <mailto:simon at cttmar.univali.br>
> DataBase Manager, Mapserver, OracleSpatial and PostGis Developer
> G10 - Laboratório de Computação Aplicada
> Fone: 047 - 341 7960
> http://g10.cttmar.univali.br
> Vladimir Guzmán wrote:
>> Yes, but the information I get from the table USER_SDO_GEOM_METADATA
>> is the global extents of all the elements in the table, and I need
>> the extents of each particular element in the table.
>> For example, my table contains information about states, and if the
>> user selects one state in a combo box, I need to get this particular
>> state's extents in order to draw it with its appropiate zoom.
>> Any ideas?
>> Thanks
