[Mapserver-users] Oracle Spatial extents
Fernando S.
simon at inf.univali.br
Wed Feb 18 15:59:11 EST 2004
Vladimir,
Well, the problem can be that you didn't define SRID in your query.
Some help you can report me.
Thank's
Fernando Simon - simon at cttmar.univali.br <mailto:simon at cttmar.univali.br>
DataBase Manager, Mapserver, OracleSpatial and PostGis Developer
G10 - Laboratório de Computação Aplicada
Fone: 047 - 341 7960
http://g10.cttmar.univali.br
Vladimir Guzmán wrote:
> I have the same problem that using SDO_GEOM.SDO_MBR:
> ORA-13374: SDO_MBR not supported for geodetic data
> Do you know why my data is geodetic and yours not?
> Did I create the table in the wrong way?
> Thanks a lot.
> Vladimir Ilich Guzmán R.
> http://www.maintask.com
> Fernando S. wrote:
>> Vladimir,
>> Hi, concerning this function, I don't know if this is the correct
>> way to do it. Anyway I use this query to get the extent:
>> SELECT max(X2), max(Y2), min(X1), min(Y1) FROM (
>> SELECT SDO_GEOM.SDO_MAX_MBR_ORDINATE(h.coordenada,
>> m.diminfo, 1) AS X2
>> , SDO_GEOM.SDO_MAX_MBR_ORDINATE(h.coordenada,
>> m.diminfo, 2) AS Y2
>> , SDO_GEOM.SDO_MIN_MBR_ORDINATE(h.coordenada,
>> m.diminfo, 1) AS X1
>> m.diminfo, 2) as Y1
>> , h.codigo_ott
>> , h.codigo_dna
>> FROM hidrografia_sc h, user_sdo_geom_metadata m
>> WHERE m.table_name ='HIDROGRAFIA_SC'
>> AND m.column_name = 'COORDENADA'
>> AND h.codigo_ott = $CODE)
>> In this query HIDROGRAFIA_SC is the table that contains the
>> geometry column (COORDENADA). The $CODE is the unique identyfier of
>> table.
>> This query report:
>> MAX(X2) MAX(Y2) MIN(X1) MIN(Y1)
>> -48.64248 -26.83385 -49.69149 -27.24407
>> I don't know if I help you. Sorry my poor english.
>>> Yes, but the information I get from the table USER_SDO_GEOM_METADATA
>>> is the global extents of all the elements in the table, and I need
>>> the extents of each particular element in the table.
>>> For example, my table contains information about states, and if the
>>> user selects one state in a combo box, I need to get this particular
>>> state's extents in order to draw it with its appropiate zoom.
>>> Any ideas?
>>> Thanks
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
