[Mapserver-users] WMS Client Problem
Ed McNierney
ed at topozone.com
Wed Feb 18 22:04:29 EST 2004
Daniel -
I am just about to look into some WMS access control issues and I was
planning to try the http://user:password@host.domain.com/... route. My
concern, however, is that the online resource URI has to be described in
the MAP file as well, which would mean that each user would need to have
a unique MAP file with their own username and password embedded in it.
Does this make sense to you? Am I confused?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
Sent: Wednesday, February 18, 2004 6:21 PM
To: bartvde at xs4all.nl
Cc: Stefan Schneberger; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] WMS Client Problem
bartvde at xs4all.nl wrote:
> Hi Stefan,
> I had the exact same problem (and still have, because we have changed
> things in the firewall/proxy to solve this).
> I think you need to recompile Mapserver and libcurl to have it going
> through the proxy. Not a totally trivial task.
> I think it would be a nice enhancement to Mapserver if we could
> specify in the MAP file whether or not the WMS client needs to go
> through a proxy and then the address/URL of the proxy.
If I remember correctly it's just a few extra parameters to pass to
libcurl, so I don't think it would be too hard to support a proxy.
However I am wondering if the proxy settings should be global to the
mapfile (i.e. in the WEB object), or local to the WMS layer (i.e.
wms_proxy_* metadata). It seems to me that it would make sense to have
a single set of parameters in the web object, but I don't know if there
are cases where someone needs different proxies to get to different
hosts.
I have created a bug to discuss this, please add your comments there:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=571
> Also some kind of authentication
> support for the WMS client would be nice.
Does it work if you use http://user:password@host.domain.com/... in the
online resource? If not then please create a enhancement bug for this
and I'll see what can be done.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
