[Mapserver-users] WMS Client Problem
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Feb 18 23:31:12 EST 2004
Ed McNierney wrote:
> I am just about to look into some WMS access control issues and I was
> planning to try the http://user:password@host.domain.com/... route. My
> concern, however, is that the online resource URI has to be described in
> the MAP file as well, which would mean that each user would need to have
> a unique MAP file with their own username and password embedded in it.
> Does this make sense to you? Am I confused?
I see what you mean, I think there are (at least) two possible
situations for authentication:
1- The case where MapServer always uses the same user/password to
connect to the server. In this case it is enough to store the
user/password in the mapfile I think.
2- The case where you want to cascade credentials coming from the
client, which is what you're talking about here.
I think #1 and #2 can and should be handled separately. #1 is quite
straightforward and should be easy to implement, but #2 would definitely
need more thinking and more work.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
