[Mapserver-users] Mapscript, Debian & Server Error
Vincenzo Patruno
patruno at istat.it
Fri Feb 20 03:32:15 EST 2004
Hi Humberto and thanks a lot for your answer, even if
your suggestion doesn't work on my system.
I compiled and installed suphp and I also modified my Php_4.3.4 configure as
follow:
./configure --with-msql=/usr/local/Hughes --with-regex=system --enable-for
ce-cgi-redirect --with-gd --with-zlib
--with-ttf --with-jpeg-dir --with-png-dir --with-pgsql --enable-dbase --ena
ble-session --without-mysql --with-pr
oj --with-ncurses --with-iconv --enable-cli --enable-cgi --enable-fastcgi --
enable-gd-native-ttf --enable-static
--disable-all
But Nothing...
The problem is always the same as you can check clicking on the links below
Here is also my Mapserver3.6.7 configure
./configure --with-php=/usr/local/php-4.3.4 --with-gd --enable-runpath --wit
h-freetype=/usr/local/include/freetyp
e --with-jpeg --with-png --with-postgis=yes --with-proj
----- Original Message -----
From: "Humberto Cereser Ibanez" <humberto at pastoraldacrianca.org.br>
To: "Vincenzo Patruno" <patruno at istat.it>
Cc: "Mapserver" <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, February 19, 2004 1:35 PM
Subject: Re: [Mapserver-users] Mapscript, Debian & Server Error
> Vincenzo Patruno wrote:
> > Hi all!
> > Unfortunately two weeks ago my server said me "goodbye" and crashed.
> > (Hard Disk problem)
> > So I found a new server and I began installing all software I needed.
> > So I installed Mapserver - Mapscript 3.6.7 (My application uses
> > 'addcolor' that isn't supported by Mapserver 4)
> > and I installed also PHP (4.2.3, but I installed also all versions up
> > to 4.3.4)
> > You can check the system clicking on
> > http://www.geodemo.istat.it/test.php
> > and
> > http://www.geodemo.istat.it/itasca/demo_init.html
> > But when I test my application The system has a strange behaviour
> > If you go to
> > http://www.geodemo.istat.it/gpop2001/index_e.orig.php
> > and click "Map" the system display correctely a map
> > This appens also if you select "All provinces" and "All Regions" on
> > the left side of the screen
> > But if you select a Geographical area other than "Italy" and you click
> > "Map" the system display an error.
> > In the error_log file you can find: "Premature end of script headers:
> > /usr/local/apache/cgi-bin/php"
> > We have the same problem using maplab.
> > http://www.geodemo.istat.it/maplab/htdocs/index.phtml
> > If you open the tutorial project and you want to display the preview
> > of the mapfile, you obtain the same error.
> > I think the problem is related somehow to display more than one layer.
> > Infact, in "Geodemo" application the system fails exactly when more
> > than one layer sould be displayed
> > (This happens also if you zoom in)
> > Any idea?
> > ... On the new system I installed last version of Debian (3.0) while I
> > used Red Hat 7.3 on the previous system
> > Thanks in advance
> > V
> Hi Vincenzo
> I had the same problem with php-4.3.3
> I followed the advice in
> http://www.debianhowto.de/howtos/en/suphp/suphp_installation.html
> excepting for instalation of pakage php4-cgi. I install php from sources.
> My php-4.3.4 configure:
> /configure --prefix=/usr/local --with-gd=/usr/local
> --with-proj=/usr/local
> --with-gdal=/usr/local/src/gdal-1.1.9/apps/gdal-config
> --with-curl=/usr/local --with-pgsql=/usr/local/src/postgresql-7.2.1/src
> /usr/include/postgresql /usr/lib --with-ncurses --with-regex=system
> --without-mysql --with-freetype-dir=/usr/local --with-iconv --with-zlib
> --with-t1lib=/usr/include --with-iconv --enable-cli --enable-cgi
> --enable-force-cgi-redirect --enable-fastcgi --enable-gd-native-ttf
> --enable-static --enable-dbase
> Good luck!
> Pastoral da Criança
> Curitiba - PR - Brasil
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
