[Mapserver-users] Mapscript causes core dump on Solaris
Carsten Heidmann
heidmann at Hamburg.BAW.DE
Mon Feb 23 23:54:05 PST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I had problems running mapscript (4.0.1) applications on Solaris 8 (SPARC).
Applications developed with the current Maplab version didn't run and
caused mapscript to terminate with a core dump.
My current workaround is to disable/delete the lines with ANTIALIAS ... in
the mapfile.
I suspect that the basic problem is the usage of a precompiled libpng from
www.sunfreeware.com. I haven't yet tested compiling libpng by myself but I
will write if this solves the problem.
Carsten
Dipl. Geogr. Carsten Heidmann Bundesanstalt fuer Wasserbau
Tel.: +49 (0)40 81908-345 - Dienststelle Hamburg -
Fax: +49 (0)40 81908-373 Wedeler Landstrasse 157
heidmann at hamburg.baw.de DE - 22559 Hamburg
http://nokis.baw.de/ http://www.hamburg.baw.de/
PGP-Key ID: 0xFF489EAE
PGP-Signatur: http://www.keyserver.net/
-----BEGIN PGP SIGNATURE-----
Version: 6.5.8ckt
iQA/AwUBQDr1ALjxzYr/SJ6uEQJaMQCgm58K71Yqjq3Xp3GoAhl+9i1+CDIAoNKz
h7o0qlE0XhFi35ZHOqUwhIef
=hVge
-----END PGP SIGNATURE-----
More information about the MapServer-users
