[Mapserver-users] Re: FW: SaveQuery & Queryfile
Richard Greenwood
rich at greenwoodmap.com
Tue Feb 24 09:57:48 EST 2004
Werner du Plessis wrote:
> Hi Richard,
> That is how I have it setup. The query executes and find the features. Now I want to zoom in twice for example, with the first click the query persists, zoom's closer and retains my selected features. On the second click I get the following error:
> msLoadQuery(): Unable to access file. (c:/inetpub/wwwroot/tmp/map.map10776342052696.qy)
map.map in the line above does not look correct. Your query file name is
getting thrashed.
> Any idea's?
> Regards
> Werner
> -----Original Message-----
> From: Richard Greenwood [mailto:rich at greenwoodmap.com]
> Sent: Tuesday, February 24, 2004 4:39 PM
> To: Werner du Plessis; mapserver-users at lists.gis.umn.edu
> Subject: Re: FW: SaveQuery & Queryfile
>>Hi Richard,
>>I see from a posting on mapservers user forum that you have had a similar problem. My query results are also persistent only for the first interaction on the map after the query results are displayed. After that I get the error: msLoadQuery(): Unable to access file.
> 1. When you execute the query, you must set savequery=true. Mapserver
> will then create a .qy file. Check in your tmp directory to see if the
> .qy file has been created.
> 2. You must get the name of the query file from mapserver. Something
> like the following will work:
> <input type='hidden' name='queryfile' value='[queryfile]'>
> 3. With each subsequent form submission, be sure the name is passed back
> to mapserver e.g.:
> queryfile=tc10776330262312.qy
> (The above hidden form variable will do this)
Richard Greenwood
www.greenwoodmap.com
