[Mapserver-users] Layers added but not displayed !!!
woodbri at swoodbridge.com woodbri at swoodbridge.com
Thu Feb 26 06:53:47 PST 2004
The objects with TYPE none can not be displayed as they have NO
geometry. For example altname is just a list of TLIDs and alternate
names for those TLIDs.
You don't have any text labels because you have not defined any in
your mapfile under the appropriate layers.
-Steve W.
On 26 Feb 2004 at 9:52, Dharani Babu wrote:
> Hi all ,
> I am new bie who started working on mapserver with the help of the members
> of this group .
> ( credit goes to Tyler Mitchell , Paul spencer !!) .
> I am trying to render TIGER files with OGR CONNECTION TYPE. I downloaded the
> tiger files  and have rendered the completechain of new hampshire -
> rockingham county . Its cool . I found the extent , layers details with
> ogrinfo .exe of GDAL . The output of ogrinfo <tiger folder> gaveme the
> following list of layers ::
> Had to open data source read-only.
> INFO: Open of `c:/ms4w/apache/htdocs/demof/data/rm'
> using driver `TIGER' successful.
> 1: CompleteChain (Line String)
> 2: AltName (None)
> 3: FeatureIds (None)
> 4: ZipCodes (None)
> 5: Landmarks (Point)
> 6: AreaLandmarks (None)
> 7: KeyFeatures (None)
> 8: Polygon (None)
> 9: EntityNames (Point)
> 10: IDHistory (None)
> 11: PolyChainLink (None)
> 12: PIP (Point)
> 13: TLIDRange (None)
> 14: ZipPlus4 (None)
> Now I can see the CompleteChain which displays the line work of the county .
> And I added the layers for Landmarks ( 5) , EntityNames (9) , PIP ( 12) also
> . Now I got a map with dots everywhere denoting landmarks and PIP . But I
> dont find any of the “Entity Names “ Why so ? And more over I expect the
> addition of Entity Names will display the Locations , city names , landmark
> names etc on the map . Am I right ? or missing something ? And what are the
> significance of other layers like AltName , FeatureIDs ,ZipCodes vis-vis
> rendering the map ?
> When I tried to add the layers without geometry (TYPE  none ) what should be
> the TYPE value in LAYER definition ? And Can I add them as layers first of
> all ??Are they renderable or they are meant for some other purpose ??:)
> My map file is as follows . Could any of you help  me ? Thanks in advance
> dharani
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 800 800
> EXTENT -71.451310 42.737590 -70.575094 43.274201
> #UNITS DEGREES
> SHAPEPATH "C:/ms4w/apache/htdocs/demof/data/rm/"
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> # Projection definition, consult the PROJ.4 documentation for parameter
> discussi
> #PROJECTION
> #  "proj=utm"
> #  "ellps=GRS80"
> #  "zone=10"
> #  "north"
> #  "no_defs"
> #  "init=EPSG:26910"
> #END
> # Start of web interface definition
> WEB
>   HEADER tiger
>   TEMPLATE temp_rm2.html
>   FOOTER demo_footer.html
> #  MINSCALE 1000
> #  MAXSCALE 1550000
>   IMAGEPATH "C:/ms4w/apache/htdocs/temp_rm2/"
>   IMAGEURL "/temp_rm2/"
>   # LOG "demo.log"
> END
> QUERYMAP
>   SIZE 200 200
>   STATUS ON
>   STYLE HILITE
>   COLOR 255 0 0
> END
> # Start of reference map
> REFERENCE
>   IMAGE graphics/dem.gif
>   EXTENT 481314.93 5620068.63 703440.19 5837331.76
>   SIZE 200 192
>   STATUS OFF
>   COLOR -1 -1 -1
>   OUTLINECOLOR 255 0 0
> END
> # Start of legend
> LEGEND
>   KEYSIZE 18 12
>   LABEL
>     TYPE BITMAP
>     SIZE MEDIUM
>     COLOR 0 0 89
>   END
>   STATUS ON
> END
> # Setting up output formats
> OUTPUTFORMAT
>   NAME png
>   DRIVER "GD/PNG"
>   MIMETYPE "image/png"
>   IMAGEMODE RGB #PC256
>   EXTENSION "png"
> END
> # Start of scalebar
> SCALEBAR
>   LABEL
>     COLOR 255 255 255
>     SIZE tiny
>   END
>   STYLE 1
>   SIZE 50 2
>   COLOR 255 255 255
>   UNITS KILOMETERS
>   INTERVALS 1
>   TRANSPARENT TRUE
>   STATUS TRUE
> END
> SYMBOL
>   NAME "circle"
>   TYPE ellipse
>   FILLED true
>   POINTS
>     1 1
>   END
> END
> # Start of layer definitions
> LAYER
> GROUP tigerdata
> NAME tiger1
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "C:/ms4w/apache/htdocs/demof/data/rm"
> DATA "CompleteChain"
> CLASS
> SYMBOL "circle"
> SIZE 1
> COLOR 200 0 0
> END
> END
> LAYER
> GROUP tigerdata
> NAME tiger5
> TYPE POINT
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> DATA "Landmarks"
> CLASS
> SYMBOL "circle"
> SIZE 4
> COLOR 0 200 0
> END
> END
> LAYER
> GROUP tigerdata
> NAME tiger9
> TYPE POINT
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> DATA "EntityNames"
> CLASS
> SYMBOL "circle"
> SIZE 1
> COLOR 0 0 200
> END
> END
> LAYER
> GROUP tigerdata
> NAME tiger12
> TYPE POINT
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> DATA "PIP"
> CLASS
> SYMBOL "circle"
> SIZE 1
> COLOR 0 0 200
> END
> END
> END  # Map file
> _________________________________________________________________
> Raja Ravi Varma paintings. Buy art prints.
> http://go.msnserver.com/IN/42737.asp At MSN Shopping.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
