[Mapserver-users] Layers added but not displayed !!!
Dharani Babu dharanibabus at hotmail.com
Thu Feb 26 21:34:34 PST 2004
Thanks steve
  I got it . Ofcourse the non geomterical layers can not be projected . But
as u said
>You don't have any text labels because you have not defined any in
>your mapfile under the appropriate layers.
What exactly the LAYERS under which I can define TEXT labels ? I searched
for them in mapfile reference but could nt get to the point . Simply putting
I need the "city names , location names " on the map . As of now I have got
Landmarks and PIP in the map as they are stright forward POINT geometry . I
assume the "EntityNames" layer out of the TIGER files thro ogrinfo.exe  is
the one that contains names . Am I right ? Please shed some light on this ..
with regards and thanks in advance
dharani
>From: woodbri at swoodbridge.com
>Reply-To: woodbri at swoodbridge.com
>To: mapserver-users at lists.gis.umn.edu,              "Dharani Babu"
><dharanibabus at hotmail.com>
>Subject: Re: [Mapserver-users] Layers added but not displayed !!!
>Date: Thu, 26 Feb 2004 09:53:47 -0500
>The objects with TYPE none can not be displayed as they have NO
>geometry. For example altname is just a list of TLIDs and alternate
>names for those TLIDs.
>-Steve W.
>On 26 Feb 2004 at 9:52, Dharani Babu wrote:
> > Hi all ,
> > I am new bie who started working on mapserver with the help of the
>members
> > of this group .
> > ( credit goes to Tyler Mitchell , Paul spencer !!) .
> > I am trying to render TIGER files with OGR CONNECTION TYPE. I downloaded
>the
> > tiger files  and have rendered the completechain of new hampshire -
> > rockingham county . Its cool . I found the extent , layers details with
> > ogrinfo .exe of GDAL . The output of ogrinfo <tiger folder> gaveme the
> > following list of layers ::
> > Had to open data source read-only.
> > INFO: Open of `c:/ms4w/apache/htdocs/demof/data/rm'
> > using driver `TIGER' successful.
> > 1: CompleteChain (Line String)
> > 2: AltName (None)
> > 3: FeatureIds (None)
> > 4: ZipCodes (None)
> > 5: Landmarks (Point)
> > 6: AreaLandmarks (None)
> > 7: KeyFeatures (None)
> > 8: Polygon (None)
> > 9: EntityNames (Point)
> > 10: IDHistory (None)
> > 11: PolyChainLink (None)
> > 12: PIP (Point)
> > 13: TLIDRange (None)
> > 14: ZipPlus4 (None)
> > Now I can see the CompleteChain which displays the line work of the
>county .
> > And I added the layers for Landmarks ( 5) , EntityNames (9) , PIP ( 12)
>also
> > . Now I got a map with dots everywhere denoting landmarks and PIP . But
>I
> > dont find any of the “Entity Names “ Why so ? And more over I expect the
> > addition of Entity Names will display the Locations , city names ,
>landmark
> > names etc on the map . Am I right ? or missing something ? And what are
>the
> > significance of other layers like AltName , FeatureIDs ,ZipCodes vis-vis
> > rendering the map ?
> > When I tried to add the layers without geometry (TYPE  none ) what
>should be
> > the TYPE value in LAYER definition ? And Can I add them as layers first
>of
> > all ??Are they renderable or they are meant for some other purpose ??:)
> > My map file is as follows . Could any of you help  me ? Thanks in
>advance
> > dharani
> > # Start of map file
> > NAME DEMO
> > STATUS ON
> > SIZE 800 800
> > EXTENT -71.451310 42.737590 -70.575094 43.274201
> > #UNITS DEGREES
> > SHAPEPATH "C:/ms4w/apache/htdocs/demof/data/rm/"
> > IMAGECOLOR 255 255 255
> > IMAGETYPE png
> > # Projection definition, consult the PROJ.4 documentation for parameter
> > discussi
> > #PROJECTION
> > #  "proj=utm"
> > #  "ellps=GRS80"
> > #  "zone=10"
> > #  "north"
> > #  "no_defs"
> > #  "init=EPSG:26910"
> > #END
> > # Start of web interface definition
> > WEB
> >   HEADER tiger
> >   TEMPLATE temp_rm2.html
> >   FOOTER demo_footer.html
> > #  MINSCALE 1000
> > #  MAXSCALE 1550000
> >   IMAGEPATH "C:/ms4w/apache/htdocs/temp_rm2/"
> >   IMAGEURL "/temp_rm2/"
> >   # LOG "demo.log"
> > END
> > QUERYMAP
> >   SIZE 200 200
> >   STATUS ON
> >   STYLE HILITE
> >   COLOR 255 0 0
> > END
> > # Start of reference map
> > REFERENCE
> >   IMAGE graphics/dem.gif
> >   EXTENT 481314.93 5620068.63 703440.19 5837331.76
> >   SIZE 200 192
> >   STATUS OFF
> >   COLOR -1 -1 -1
> >   OUTLINECOLOR 255 0 0
> > END
> > # Start of legend
> > LEGEND
> >   KEYSIZE 18 12
> >   LABEL
> >     TYPE BITMAP
> >     SIZE MEDIUM
> >     COLOR 0 0 89
> >   END
> >   STATUS ON
> > END
> > # Setting up output formats
> > OUTPUTFORMAT
> >   NAME png
> >   DRIVER "GD/PNG"
> >   MIMETYPE "image/png"
> >   IMAGEMODE RGB #PC256
> >   EXTENSION "png"
> > END
> > # Start of scalebar
> > SCALEBAR
> >   LABEL
> >     COLOR 255 255 255
> >     SIZE tiny
> >   END
> >   STYLE 1
> >   SIZE 50 2
> >   COLOR 255 255 255
> >   UNITS KILOMETERS
> >   INTERVALS 1
> >   TRANSPARENT TRUE
> >   STATUS TRUE
> > END
> > SYMBOL
> >   NAME "circle"
> >   TYPE ellipse
> >   FILLED true
> >   POINTS
> >     1 1
> >   END
> > END
> > # Start of layer definitions
> > LAYER
> > GROUP tigerdata
> > NAME tiger1
> > TYPE LINE
> > STATUS DEFAULT
> > CONNECTIONTYPE OGR
> > CONNECTION "C:/ms4w/apache/htdocs/demof/data/rm"
> > DATA "CompleteChain"
> > CLASS
> > SYMBOL "circle"
> > SIZE 1
> > COLOR 200 0 0
> > END
> > END
> > LAYER
> > GROUP tigerdata
> > NAME tiger5
> > TYPE POINT
> > STATUS DEFAULT
> > CONNECTIONTYPE OGR
> > DATA "Landmarks"
> > CLASS
> > SYMBOL "circle"
> > SIZE 4
> > COLOR 0 200 0
> > END
> > END
> > LAYER
> > GROUP tigerdata
> > NAME tiger9
> > TYPE POINT
> > STATUS DEFAULT
> > CONNECTIONTYPE OGR
> > DATA "EntityNames"
> > CLASS
> > SYMBOL "circle"
> > SIZE 1
> > COLOR 0 0 200
> > END
> > END
> > LAYER
> > GROUP tigerdata
> > NAME tiger12
> > TYPE POINT
> > STATUS DEFAULT
> > CONNECTIONTYPE OGR
> > DATA "PIP"
> > CLASS
> > SYMBOL "circle"
> > SIZE 1
> > COLOR 0 0 200
> > END
> > END
> > END  # Map file
> > _________________________________________________________________
> > Raja Ravi Varma paintings. Buy art prints.
> > http://go.msnserver.com/IN/42737.asp At MSN Shopping.
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
