[Mapserver-users] Mapscript
    Lowell Filak
    lfilak at medinaco.org
    Thu Feb 26 13:14:28 PST 2004
Both/most versions of Mapscript work fine and will do the job, but what
you use should fit what you prefer and may be dictated by what platform
your running on.
If someone recommends a particular flavor and it is not where your
experience is and you start running into trouble then it can be a real
bear to track down the bug.
IMHO
Lowell
The following message was sent by =?iso-8859-1?q?Jose=20Maria=20Michia?=
<josemariamichia at yahoo.com.ar> on Thu, 26 Feb 2004 14:21:04 -0300 (ART).
> Hi.
> I have a Tomcat Application that uses Mapscript (Java Interface)
trought an RMI Server in a n-layer. This is useful for no tomcat crash,
but the rmi crash. So, my application never die..... but the performance
is bad, and no error message. I never know what is wrong. I decide
maintain the java applicaction and put the mapserver work in a PHP
application or Perl application. This application will generate some XML
with tags like MAP_IMAGE_NAME, MAP_EXTENT, etc.... Maybe identify
implementations, and add some dinamyc layers. What interface recommend
you? Perl or Mapscript?
> Thanks, sorry my english.
> http://visualizador.rosario.gov.ar (non stable). I hope replace RMI
with php or perl in the next version. Next version come with some
interesting funcionality, like custom querys, new important layers
(urban transport), and tips for the custom querys result objets)....
Cooming soon :D
> People: I have very bad experience with Java interface. I recommend
you no use Java interface (or use only y little static mapping. If you
no change the MAP file , and no add runtime objetcs, maybe you don´t
have problems).
> José María Michia
>  ¿Buscás un auto?
> Encontralo en Yahoo! Autos
> ¡Más de 4000 clasificados todos los días!
> Usados - 0 km - Vendé el tuyo
More information about the MapServer-users
