[Mapserver-users] Help with TIGER+ MAP file !!!!
Dharani Babu
dharanibabus at hotmail.com
Fri Feb 27 03:18:09 EST 2004
Hi all
I request help from any of u who work with TIGER + MapServer . My system is
win Xp / 2k .
I am using TIGER line files with map server for my mapping application .
As of now I am able to render the base map - CompleteChain with Landmarks
/PIP of the TIGER files ( TGR33015 - of Rockingham - NH ) . But I am
searching to find ways to add the NAMES of the locations . like city n, town
, street , road names . I got a reply to similar request to add TEXT
LABELS to be specified . I understand that we can render the layers from the
list generated by ogrinfo.exe . I ran the ogrinfo.exe and got the following
layers
Had to open data source read-only.
INFO: Open of `c:/ms4w/apache/htdocs/demof/data/rm'
using driver `TIGER' successful.
1: CompleteChain (Line String)
2: AltName (None)
3: FeatureIds (None)
4: ZipCodes (None)
5: Landmarks (Point)
6: AreaLandmarks (None)
7: KeyFeatures (None)
8: Polygon (None)
9: EntityNames (Point)
10: IDHistory (None)
11: PolyChainLink (None)
12: PIP (Point)
13: TLIDRange (None)
14: ZipPlus4 (None)
I persume the layer "EntityNames" refer to the names that appear on the map
right ?
If so how to use them in map file reference ?
my map file is as follows ...
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT -71.451310 42.737590 -70.575094 43.274201
#UNITS DEGREES
SHAPEPATH "C:/ms4w/apache/htdocs/demof/data/rm/"
IMAGECOLOR 255 255 255
IMAGETYPE png
# Projection definition, consult the PROJ.4 documentation for parameter
discussi
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=10"
# "north"
# "no_defs"
# "init=EPSG:26910"
#END
# Start of web interface definition
WEB
HEADER tiger
TEMPLATE temp_rm2.html
FOOTER demo_footer.html
# MINSCALE 1000
# MAXSCALE 1550000
IMAGEPATH "C:/ms4w/apache/htdocs/temp_rm2/"
IMAGEURL "/temp_rm2/"
# LOG "demo.log"
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/dem.gif
EXTENT 481314.93 5620068.63 703440.19 5837331.76
SIZE 200 192
STATUS OFF
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Setting up output formats
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB #PC256
EXTENSION "png"
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 50 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
# Start of layer definitions
LAYER
GROUP tigerdata
NAME tiger1
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "C:/ms4w/apache/htdocs/demof/data/rm"
DATA "CompleteChain"
CLASS
SYMBOL "circle"
SIZE 1
COLOR 200 0 0
END
END
LAYER
GROUP tigerdata
NAME tiger5
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE OGR
DATA "Landmarks"
CLASS
SYMBOL "circle"
SIZE 4
COLOR 0 200 0
END
END
LAYER
GROUP tigerdata
NAME tiger9
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE OGR
DATA "EntityNames"
CLASS
SYMBOL "circle"
SIZE 1
COLOR 0 0 200
END
END
_________________________________________________________________
Raja Ravi Varma paintings. Buy art prints.
http://go.msnserver.com/IN/42737.asp At MSN Shopping.
