[Mapserver-users] MySQL and Mapserver
Paul Spencer
spencer at dmsolutions.ca
Sat Jan 3 16:27:38 EST 2004
Bart,
if you are interested in point geometries only, there is a new format in
OGR to set up a virtual layer that can draw columns from any ODBC data
source and map two of the columns to x and y locations. We've used it
for a couple of clients and it works very nicely. If you are interested
I can send you more details.
Cheers,
Paul
Bart van den Eijnden wrote:
> Hi list,
> I see in the history log that there has been some work done recently
> (early December) by Attila on supporting MySQL 4.X for the MyGIS
> connector. Can it be used already?
> Also, is it possible to keep the geometries in shapefiles and use
> Mapserver JOINS to link to tables in MySQL?
> Thanks in advance for the info.
> Best regards,
> Bart
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
