[Mapserver-users] jBox
Wim Blanken PI
wim.blanken at planet.nl
Wed Jan 21 13:10:44 EST 2004
This is a multi-part message in MIME format.
--Boundary_(ID_Cr1kzHME+8/55aJ9VAP29g)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: 7BIT
Hello Michael,
Two possible solutions:
1. Please check if you got the case of the text right.
2. The jbox applet does not function on MS VM if you have downloaded it from
the mapserver utilities section. It was compiled with a JDK not compatible
with 1.1. You have to recompile it with a java compiler (for example in SDK
1.4 with: javac -target 1.1 jBox.class). If you use JRE instead if MS VM
than it will work OK.
3. Use the Jbox.class that I have included in this mail. Please beare in
mind that I have changed this Jbox in order to include digitising functions.
Regards,
Wim Blanken
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, January 21, 2004 6:42 PM
Subject: [Mapserver-users] jBox
> I have jBox installed on windows 2000 IIS 5. I followed (I think) the
> instructions on installing. Created wwwroot/java/jBox/ folder and copied
> evalThread.class, jBox.java, and jBox.class to that directory. I then
made
> modifications to my html file and everthing seems to work other than I am
> getting a "gray box" where my map used to be. Does anyone have any ideas
> what I may have missed?
> Inserted in head of html:
> <SCRIPT LANGUAGE="JavaScript">
> function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
> document.mapserv.imgbox.value = minx + " " + miny + " " +
> maxx + " " + maxy;
> document.mapserv.imgxy.value = minx + " " + miny;
> function seterror_handler(message) {
> alert(message);
> </SCRIPT>
> Inserted this into the body of the html:
> <tr>
> <td colspan="2">
> <applet codebase="/java/jBox" code="jBox.class" width="600"
> height="600" name="jBox" MAYSCRIPT>
> <param name="image" value="http://[host][img]">
> </applet>
> </td>
> </tr>
> AND
> <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
> Michael Smith, Planner II
> City of San Angelo
> Planning & Development
> 325.657.4210 Fax: 325.481.2648
> Email: msmith at sanangelompo.org
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-type: application/x-zip-compressed; name=jBox.zip
Content-transfer-encoding: base64
Content-disposition: attachment; filename=jBox.zip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--Boundary_(ID_Cr1kzHME+8/55aJ9VAP29g)--
